351 heads fit on 289? - Mustang Evolution
Old 02-19-2011, 06:16 PM   #1
Willa set of 351 heads work on a 289?
93 coupe lx is offline   Reply With Quote
Old 02-19-2011, 06:33 PM   #2
I know they will fit a 302 so I don't see why they wouldn't. There's different headbolts due to the holes in the heads are bigger. Svtlx would prob be the guy to talk to about it further. He's all over those pushrod motors.
Alscobra is offline   Reply With Quote
Old 02-21-2011, 09:03 AM   #3
stampde's Avatar
Re: 351 heads fit on 289?
they bolt right on , the 51 has bigger head bolts so you'll need bushing/washers for your head bolts ... Edelbrock makes them
2011 GT Auto
Old 02-24-2011, 09:55 PM   #4
Ok thanks I'll look into the bolts and washers
Old 02-24-2011, 10:56 PM   #5
silverstangboy's Avatar
you'll lose a considerable amount of compression unless you cut the head down alot
just think your pulling the piston up and down 3" on a 302 verses 3.5" on the 351, the head has more room in it to make up for the added compression ratio. not such a bad thing if your throwing it on a stroker.
93 mustang notch
~450hp 331 stroker - Sold
Old 02-25-2011, 07:29 AM   #6
9Sec93LX's Avatar
If you can find an older set of heads from a 351 windsor the chamber size is smaller. These start with a C = 60's and D = 70's. example C9 =69, D0 = 70 Etc. 351W heads also have the benefit of larger valve sizes 1.84" int vs. 1.78" on the 289, and 1.54" exh. vs 1.46" on the 289. Only problem with the older heads is they don't have the hardened valve seats like modern heads do. So running unleaded gas is kinda hard on them. You can have the seats cut out and hardened ones installed, but that gets into a bit of money.
Unless you're going for the OEM look you're much better off starting with a set of GT-40 heads, these have the same valve sizes as the 351 W heads do. Not the GT-40P's though,(which came factory fitted on Ford Exploder's) those have a funky spark plug location and require GT-40P specific headers, which may not be available for your particular ride.
Tommy
To find out more about drag racing your 5.0 liter Mustang check out my blog by clicking here
http://www.bestracingtips.com/2010/08/
9Sec93LX is offline   Reply With Quote
Old 02-25-2011, 05:17 PM   #7
Yes, what he saidith!
93 mustang notch
« Best clutch | heads »
351 Windsor for 289 J&J 1965 Classic Mustangs 0 03-20-2009 07:50 PM
5.8(351) E7TE Heads... Fast93Coupe 1979-1995 Mustang GT 10 12-22-2007 08:39 AM
09:03 PM
