What next? - Mustang Evolution
Old 02-22-2011, 05:55 PM   #1
Albaraptor's Avatar
What next?
Ok here's my mod list so far. 5.0 engine with underdrive pulleys , 70 mm throttle body,BBK cold air intake, Pro M 75 mm mass air meter, msd distributor,shorty headers, BBK xpipe and flowmasters. I have the egr deleted and smog pump deleted. I also have 3.73 gears. What should I do next?
Albaraptor is offline   Reply With Quote
Old 02-22-2011, 06:38 PM   #2
bbunt302's Avatar
I would start saving up for heads, cam and intake. Depends on how much power you want though. You may be better off with a blower.
Scary stuff.
Old 02-22-2011, 09:06 PM   #3
Titus Wadicus
svtlx's Avatar
Re: What next?
+1...blower!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-02-2011, 05:07 PM   #4
gixxer007's Avatar
Re: What next?
Turbo it
Thats what I have been thinking about lately for the Fox Just bought. Plating with the idea to sell my blower and turbo the baby.
gixxer007 is offline   Reply With Quote
Old 03-02-2011, 05:18 PM   #5
Blower. Bolt on easy horsepower.
Alscobra is offline   Reply With Quote
07:48 PM
