Problem with gt40p spark plugs want some good spark plugs but most wont fit?? - Mustang Evolution
Old 02-27-2011, 07:31 PM   #1
i got gt40 p heads and had a time geting the spark plugs out wen i do they definatly needed to e changed they were auto lites the cheap ones ..... well i went out and got the double platinum ones 4.99 a piece well after trying for about an hour in all positions i couldnt get them to go so figuring the threads were messed up when i took them out i tried one of the old ones and low and behole went right in!!! the cheap autolite ... doesn ne one else know of this problem and if so doesn ne one know what kind of good spark plugs will fit other than the cheap ones???
If both wheels aint spinning then i aint grinning
Justbust1n is offline   Reply With Quote
Old 02-27-2011, 07:57 PM   #2
Svtlx is pretty much a 5.0 expert. Pm him. And trust his advice. He knows his ****
Old 02-27-2011, 08:24 PM   #3
bbunt302's Avatar
Autolites are probably the best plug you can buy for a 5.0. Don't buy in to the quadruple platinum, gold tip, laced with fairy dust hype. Get the part number for the autolites and buy a new set. Problem solved.
Scary stuff.
Old 02-27-2011, 08:43 PM   #4
I got those 4 ground strap platinums. Only cause they were free. They work great tho. If the autolites are a 2 piece I would steer clear. Sucks when they break off
Old 02-28-2011, 11:58 PM   #5
Re: Problem with gt40p spark plugs want some good spark plugs but most wont fit??
yea the only ones that seem to fit in the head are the cheap auto lites the double platinum auto lite have a bigger body and thread so the wont go.. didnt know if ne one had these heads and had other plugs without tapping the hole bigger
Old 03-01-2011, 01:51 AM   #6
Yeah, definitely not worth doing all that. "Cheap" autolites will do ya just fine!
93CobraGuy is offline   Reply With Quote
Old 03-01-2011, 04:20 PM   #7
When you purchased them did you ask for plugs for a 96-00 5.0 explorer? I have been using the 3.00 autolites for about a yr in mine no probs at all. Will get you the # I'm using when I get home
347 efi with GT40-p ported and polished heads GT40 upper and lower intake
Calepy86 is offline   Reply With Quote
Spark plugs? NeedSomeMods Pre-2005 V6 Mustang 35 03-01-2011 05:55 PM
Spark plugs upton7 General Mustang Discussion 15 02-02-2010 03:00 PM
spark plugs v6stang04 Pre-2005 V6 Mustang 4 01-24-2010 07:22 PM
What spark plugs should I go with? Frogleg 1996-2004 Mustang GT 30 06-21-2009 04:44 AM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 06:36 PM
02:08 AM
