Really two oil plugs - Mustang Evolution
Old 02-28-2011, 06:45 PM   #1
Just curious while pulling out my tranny saw what looks like two oil plugs on the oil pan. Is there really two? Sorry it's a 94 5.0
HaulinTwinz is offline   Reply With Quote
Old 03-01-2011, 08:09 AM   #2
Re: Really two oil plugs
yea I think the 5.0's have two I believe.
Old 03-01-2011, 09:06 AM   #3
Yes. That is exactly the case. One in the front of the pan, one in the rear.
93CobraGuy is offline   Reply With Quote
Old 03-01-2011, 03:15 PM   #4
Yes there are 2 and you gotta drain the oil in both when doing an oil change other wise you have almost a qt or so of the old still there
Calepy86 is offline   Reply With Quote
Old 03-01-2011, 04:46 PM   #5
Thanks
Old 03-01-2011, 05:08 PM   #6
06mustangmike's Avatar
i never new that,pulling both makes sense.
06mustangmike is offline   Reply With Quote
Old 03-03-2011, 02:02 PM   #7
Blustreek's Avatar
Region: Hawaii
yeah........try doin' an oil/filter change on it on the ground w/no ramps or jack stands...IT'S A *****!!!!!!!!!
Blustreek is offline   Reply With Quote
Old 03-03-2011, 02:47 PM   #8
My 2000 isn't even lowered and it's physically impossible for me to do it without jacking it up. The bright side is that once you jack up the front it makes the car angle and all the oil vacates quickly. And for any newbs USE JACK STANDS. Do not get under car without them. 20 dollar investment that you will use again can spare your life. I have seen hydraulic jacks fail or if a seal has a slow leak it will compress. Be safe guys. Dying over an oil change or any under car work isn't worth it.
Built 2 Last
Old 03-03-2011, 06:16 PM   #9
I could probably do it like that on the vert, but the Cobra, that thing sits way too low to even slide under it at all.
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Just changed plugs on 99 cobra, tubes filled with oil??!! disneyfun1 1996-2004 Mustang GT 9 12-16-2010 03:37 PM
oil on top of plugs jimmy_beaner 1996-2004 Mustang GT 14 05-13-2010 03:54 PM
best plugs bosscityboy86 1996-2004 Mustang GT 13 09-12-2006 06:11 AM
10:20 PM
