Cobra intake - Mustang Evolution
Old 03-01-2011, 04:51 AM   #1
Albaraptor's Avatar
Cobra intake
I can buy a cobra upper and lower intake for 200 used with no hardware. Would it be worth it as far as hp vs money
Albaraptor is offline   Reply With Quote
Old 03-01-2011, 06:28 AM   #2
Depends. What kind of exhaust are you running. I can't see it being worth more than 10 hp but I am sure someone will chime in that has done the swap before
Built 2 Last
Old 03-01-2011, 09:38 AM   #3
stampde's Avatar
Re: Cobra intake
Cobra imtake on a stock 5.0 worth a good 15 all day and more if your running better heads and exhaust
2011 GT Auto
Old 03-01-2011, 11:15 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Cobra intake
15 on a stock motor? im not real sure on that..but i cannot remember the flow numbers
2 hundred is a good price, but exactly what does "no hardware" entail?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-01-2011, 02:01 PM   #5
Albaraptor's Avatar
Just upper and lower intake no bolts no gaskets nothing. It's used
Old 03-01-2011, 02:03 PM   #6
Ya. That's best case scenario I think. The stocker isn't really that restrictive.... Is it svt
Built 2 Last
Old 03-02-2011, 10:01 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Cobra intake
Built 2 Last
dont get me wrong, the cobra intake isnt horrible depending on how far you wanna push it (300hp give or take). it's definatley an improvement over stock. i would try to get a v8 explorer intake, its just a revised (better flowing version) of the original cobra.
but i figure by the time you go to your local speed shop and get a few gaskets and sum bolts from the hardware store, you should still be @ or under $250 maybe $260.
for what you will have in it i will say jump on it. maybe try to talk him down a few more bucks for no bolts and gaskets.
also calculate in your larger throttle body and egr plate or it's pointless to even stick it on in the firsat place. overall itsa good deal.
Old 03-02-2011, 10:49 AM   #8
Albaraptor's Avatar
I already have a 70 mm throttle body, cai , maf and headers x pipe and flow catback
Old 03-02-2011, 10:50 AM   #9
Titus Wadicus
svtlx's Avatar
Re: Cobra intake
jump on it then bud!!!!
cobra- mach 1 intake Pureoctane2001 General Car Discussion 9 02-07-2011 09:37 AM
Cobra Intake Problem kalvanjp 1979-1995 Mustang GT 3 10-26-2010 07:30 AM
04' Cobra intake and supercharger PICS. needed if anyone can help!!! pan 1996-2004 Mustang GT 24 02-10-2009 03:33 PM
cobra intake swap 95stang_gt 1979-1995 Mustang GT 14 07-22-2008 05:40 PM
93 cobra intake Jay Rod 5.0 1979-1995 Mustang GT 29 11-21-2006 02:20 PM
01:36 AM
