underdrive pully - Mustang Evolution
Old 03-03-2011, 06:13 PM   #1
underdrive pully
How much do they reley help
spading756 is offline   Reply With Quote
Old 03-03-2011, 06:33 PM   #2
I didn't notice anything on my *** dyno, but they sure do look pretty.
93CobraGuy is offline   Reply With Quote
Old 03-03-2011, 08:59 PM   #3
That's good info... I wonder if I should sell mine then
Built 2 Last
Old 03-04-2011, 07:47 AM   #4
Re: underdrive pully
it depends on how much of an underdrive the system takes, most seem 5-10 rwhp~
Old 03-06-2011, 01:53 PM   #5
FYI I just installed march steel underdrive pulley on my 1990 lx and the charging stayed the same because the pulley for my
3g alternator was same size as the underdrive replacement. To my surprise they actually helped with cooling! Before underdrives my car would get up to 195 on highway w 180 stat and now it stays around 185! A's far A's performance I noticed a difference in acceleration! The part # was march 1000-8 on summit for $55 if anyone is interested.
SlyFox512 is offline   Reply With Quote
Old 03-07-2011, 03:28 PM   #6
How hard are they to install?
Fox351 is offline   Reply With Quote
Old 03-07-2011, 03:39 PM   #7
The only one I had any trouble with was the alternator pulley. The water pump and crank on mine were easy. 4 bolts each. Make sure to loosen the bolts with the serpentine belt still on though, makes it a lot easier to get them undone.
I did them on my '86 Vert, so not sure what year your car is, but should be simple enough. Couple of pics of mine......
Old 03-07-2011, 04:20 PM   #8
Thanks 93Cobra
Old 03-07-2011, 06:05 PM   #9
Very easy! The only one that gives people trouble is the alternator because you need a impact to take the pulley on/off. My march set came with a lock washer for the alternator nut but I used it A's a spacer b4 the pulley went on because without it A's a spacer the pulley would rub on alternator but I have a 3G alternator on my 1990 stang so with a stock alternator I'm pretty sure the spacer wouldn't be needed!
Underdrive pully 03 Yellow Stang 1996-2004 Mustang GT 5 01-20-2010 08:10 AM
Underdrive pully GhostStang 2005-2010 Mustang GT 9 10-21-2009 09:33 PM
Stock block and supercharger pully ??? sporter 2005-2010 Mustang GT 5 12-05-2008 12:54 PM
Pully system corkwood06 Pre-2005 V6 Mustang 1 12-04-2007 07:24 PM
'98 MAC Underdrive Pully Kit Installation Mustang414 Pre-2005 V6 Mustang 2 08-20-2003 12:14 PM
11:21 PM
