Whats the easiest way to 500hp - Mustang Evolution
Old 03-04-2011, 09:14 AM   #1
Just as the title reads I need to know what's the best setup to Achieve 500hp car is 89 Gt mostly stock basic bolt ons CAI cobra mass air, tb spacer , smog delete , long tubes , Cat-less X pipe car has about 45,000 on the clock I wanna keep it n/a but if I can't thats not a problem
Fox351 is offline   Reply With Quote
Old 03-04-2011, 09:16 AM   #2
SaleenFiend's Avatar
Re: Whats the easiest way to 500hp
inb4 Everett's blower comments.
I would suggest building the bottom end, Heads, cam, Intake, and Forced Induction.
Old 03-04-2011, 09:20 AM   #3
GOOD LUCK. don't see that happening without major engine work. Unless you get a BLOWER. TTT
Alscobra is offline   Reply With Quote
Old 03-04-2011, 09:35 AM   #4
What can the stock internals handle? Also how much nitrous will it hold stock
Old 03-04-2011, 09:43 AM   #5
I know and easy way to find out. Lol
Old 03-04-2011, 10:19 AM   #6
stampde's Avatar
stock bottom end ? about a 100 / 125 shot of NO2
OR JUST Hit with a 250 shot and go out in a blaze of glory !!!!
2011 GT Auto
Old 03-04-2011, 10:25 AM   #7
Hell yeah!!!!
Old 03-04-2011, 10:25 AM   #8
bbunt302's Avatar
Stock block starts to be iffy around 450 rwhp.
Scary stuff.
Old 03-04-2011, 10:27 AM   #9
Which can be translated into 500+ Flywheel HP
Old 03-04-2011, 10:30 AM   #10
Fiend. Do u know DJ Locano?
Old 5.0 went 12.6 motor 10teens on bottle.
Rebuilt bottom end.
Old 03-04-2011, 10:30 AM   #11
stampde's Avatar
Originally Posted by Alscobra View Post
Hell yeah!!!!
You and I Think alike !!!!
2011 GT Auto
Old 03-04-2011, 10:33 AM   #12
Rebuilt bottom end.
Was it a coupe? and what color?
Old 03-04-2011, 10:35 AM   #13
Silver GT. Few years ago. Procharger picked him up after. He's in a red coupe now I think.
Old 03-04-2011, 12:38 PM   #14
Thanks for the info I think I'll just spray the nuts off it and see what happens
Old 03-04-2011, 12:42 PM   #15
Spray is safe for the most part. U need to make sure you have enough fuel supply. Not enough fuel to the solenoids and boom.
Old 03-04-2011, 01:45 PM   #16
I have a Holley 155 Lph is that sufficient
Old 03-04-2011, 01:49 PM   #17
Not sure. Gonna have to see how much fuel is requires for the system.
Old 03-05-2011, 01:06 PM   #18
My friend use to have a stock bottom end, stock h/c with a cobra lower, bread box upper, a nos big shot 250hp kit and never blew anything up. We used to go street racing 3 nights a week for years. You need to run a gss340 255 lph high pressure in tank pump, atleast 24 lb injectors, good ignition so all that dope doesn't blow out the spark, the timing needs to be retarded alot, cold plugs, and most importantly the right tune. I forgot to mention that when tuned for nitrous the car runs bad on the motor.
Cobracoupe5 is offline   Reply With Quote
Old 03-05-2011, 01:30 PM   #19
IDK... name rings a bell, but probably not.
Old 03-06-2011, 11:20 PM   #20
Damn. K to achieve 500 hp your gonna need a big block or forced induction. Boost it.
Built 2 Last
Old 03-06-2011, 11:21 PM   #21
Yeeeehaaaaaaaaaa....
Built 2 Last
Old 03-07-2011, 07:26 AM   #22
by easy do you mean cheap?
Old 03-07-2011, 01:31 PM   #23
Not cheap but budget minded
Old 03-07-2011, 06:17 PM   #24
K. You need forged guts for 500 hp or your on borrowed time and out of a 5.0 your gonna have to boost it
Built 2 Last TTT
Old 03-08-2011, 02:19 PM   #25
Brett Greene's Avatar
500 whp with a stock block. Wouldn't risk it. As far as building the bottom end, I have a friend stock block built bottom end and a vortec blower and he putting down 450rwhp. But you have the chance of driving around and cracking the
Block. If you here of anyone with more than 450 on a stock block he's been very lucky so far.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 03-08-2011, 03:46 PM   #26
ibleedblue65's Avatar
I've seen over 450 to the tire on a daily driven stock block fox first hand. It its possible but I agree wit most here, around 450 is the limit. I have seen cars making 500 ish at the crank split down the middle. Revs pay a role but the thing its that a stock 5.0 block has some weak *** webbing. They split right down the middle in a sweet *** fire ball, unless you are driving of course its not so sweet.Pp
ibleedblue65 is offline   Reply With Quote
500hp S197 vs stock Nissan GTRs MUSPOR911 New Member Introductions & Greetings 8 01-09-2011 03:19 PM
Whats Up Whats Up From Georgia ShesmuRa New Member Introductions & Greetings 6 11-02-2009 02:23 PM
Ohio State Has the easiest schedule of any Top 25 Team Brent The Bar 13 10-23-2007 08:12 AM
Whats up everybody JROC New Member Introductions & Greetings 10 07-04-2006 12:20 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 10:24 PM
06:07 PM
