Car Won't Start - Mustang Evolution
Old 07-27-2007, 06:18 PM   #1
Car Won't Start
Now I have a problem with my fox 4cyl, it was running fine and all of the sudden the car shut-off and it wont start again, I checked the fuel pump and i can still hear it, the car cranks but it wont start ............can somebody help me out thanks.
joseandmarilyn is offline   Reply With Quote
Old 07-27-2007, 08:07 PM   #2
hottcobra's Avatar
Re: Car Won't Start
the pump is running but do you have fuel press. if you have fuel next check to see if you have spark. find with one you don't have than we can help a lot more
Old 07-28-2007, 04:31 PM   #3
Re: Car Won't Start
i do have spark, but yesterday afternoon i turned the key ign., and now i can barely hear the pump, this time I really need to get closed to the gas tank to hear it.
Old 07-28-2007, 10:56 PM   #4
hottcobra's Avatar
Re: Car Won't Start
you need to check fuel press. at the inspection port on the fuel rail
Old 07-29-2007, 07:23 PM   #5
Re: Car Won't Start
how do i do this?
Old 07-29-2007, 09:49 PM   #6
hottcobra's Avatar
Re: Car Won't Start
well you can use a screw driver to push the fitting in on the fuel rail to see if fuel comes out ( its just like the air fitting on your tire) if fuel comes out than get a fuel pres gauge to check press needs to be at least 40psi. if no fuel comes out than start by checking the fuel filter for a clog. if none found than you need a fuel pump
Old 07-30-2007, 03:27 PM   #7
Re: Car Won't Start
THANKS FOR ALL THE HELP........ I finally found out what was wrong with my car, my timing chain belt was broken, what i want to know is do you guys think i might have bent a valve.?
Old 09-01-2007, 01:20 PM   #8
Region: New Hampshire
Send a message via AIM to Smokedya95stang
Re: Car Won't Start
well LOL it depends on how many times u we're trying to start that car.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 09-01-2007, 07:36 PM   #9
MonteCitan's Avatar
Re: Car Won't Start
I really doubt you damaged the motor, the timing belt isn't hard to replace at all on the 2.3s and shouldn't cost too much
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-05-2007, 11:05 PM   #10
silverstangboy's Avatar
Re: Car Won't Start
I think if I were strapped for cash I'd put the belt on and then check my dynamic compression, if they all look good and high then run it as is.
if longevity is more of a concern i'd pull the head and take it too a good machinist.
93 mustang notch
~450hp 331 stroker - Sold
Old 11-19-2007, 01:56 PM   #11
Re: Car Won't Start
crappy u check the battery
candycane184 is offline   Reply With Quote
Old 02-18-2008, 12:22 PM   #12
Re: Car Won't Start
According to "AUTODATA" The 2.3 ford engine is a "freewheeling" engine so you shouldn't have to worry about valve damage. Hope this helps.
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Car won't start? Dude87 1996-2004 Mustang GT 16 10-13-2008 11:32 AM
Car won't start Torchred02 1996-2004 Mustang GT 9 02-18-2007 01:17 PM
SO you expect to start your car up... PureVenom Pictures and Videos 17 01-31-2007 02:31 PM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 06:07 PM
Should I start modding this car? mustang99vert Pre-2005 V6 Mustang 3 10-24-2004 09:50 PM
10:31 AM
