mustang gauge cluster - Mustang Evolution
Old 03-11-2011, 08:34 PM   #1
Qwik Four Six's Avatar
Well, I saw this ad on craigslist and was wondering how these go in? Not payin 650 though. http://charlotte.craigslist.org/pts/2258851436.html
My battery, oil pressure, and gas gauge all work. My temperature works sometimes, and other times it lays below 130. My tach and speedometer dont work, but ive got an aftermarket tach. Also, I called Carolina salvage and they said they've got an 88 gt and a 91 cobra sitting there. (A 91 cobra? He probably meant clone) lol. Anyway, mines a 89 and my dads is a 93 so if we can get the cluster out of those then it'll be perfect.
Qwik Four Six is offline   Reply With Quote
Old 03-12-2011, 07:47 AM   #2
MC770's Avatar
Re: mustang gauge cluster
My water temp gauge sometimes work as well
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 03-12-2011, 10:26 AM   #3
Lol. That sucks.
Old 03-12-2011, 11:00 AM   #4
Did you say you had an 89? If so I don't think a 90-93 gauge cluster will work. They have a different shape to them where the steering column goes. I could be wrong about the fitment but if they will work I have a cluster for sale for a 90-93 mustang
92mustanggt is offline   Reply With Quote
Old 03-12-2011, 11:12 AM   #5
MC770's Avatar
The 87-93 cars had the same dashes so it would work in an 89
Old 03-12-2011, 11:35 AM   #6
Yeah I know they have the same dash but there is a difference in the 87-89 and 90-93 clusters
Old 03-12-2011, 11:36 AM   #7
MC770's Avatar
Oh I got it
Old 03-12-2011, 11:37 AM   #8
I know the 90-93 won't work. But that was an aftermarket one so that's why I asked what you'd have to do yo put it in.
Old 03-12-2011, 11:39 AM   #9
Yeah, the 87-89 steering wheel and steering column was smaller, and the steering wheel was different, and the 90-93 had a different steering wheel and a bigger steering column.
Old 03-12-2011, 11:53 AM   #10
Yeah my 92 doesn't have the factory steering wheel. It's got an older wheel from a mustang before air bags were put in. If you can figure out a way to get a 90-93 cluster to work let me know because i have one for sale cheap
Old 03-12-2011, 12:15 PM   #11
Alright, don't really want to change anything. But I'll see
Old 03-15-2011, 07:18 PM   #12
Titus Wadicus
svtlx's Avatar
yea, they are definatley different. you have to take the clear plastic cover off and trim the corner of the speedo with a dremel or grinder. it's not hard at all. i got a 160mph bbk speedo. you will have to to swap the tach section tach)..but i think i may have another to drop in it. that way you can buy 92 mustanggt's and mine so u and your dad can both have one.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-15-2011, 07:35 PM   #13
Lol. Nah. I don't really wanna do that. Got enough trouble trying to get the lower control arm off. I've got a thread on that.
Old 03-17-2011, 08:57 AM   #14
Titus Wadicus
svtlx's Avatar
so do u like the aluminium pro-stock wing on my car? ima start partn out my coupe soon. i know you dont like cowl hoods (lol) so scratch that. i just know we got identical cars in and out
Old 03-17-2011, 09:18 AM   #15
Parting out. WTF? what u doing that for?
Alscobra is offline   Reply With Quote
Old 03-17-2011, 09:41 AM   #16
Titus Wadicus
svtlx's Avatar
im putting all that stuff in my 97. i hate not having leg/knee room in the notch.. no tilt wheel.... not too mention i live in an apartmentand rent 2 garages to do my work. all together i own 4 vehicles, way too many for an apartment. i could put it back together...maybe with a stock 5.0 i even even thought bout turning it into a 3.8v6, idk yet
Old 03-17-2011, 03:03 PM   #17
Don't really like the wing. I do like cowl hoods, I was just trying to get the logic of one on an efi, unless it's for looks. Cowl hoods are nice.
2011 GT gauge cluster primer2tone 2011-2014 Mustang GT 6 01-19-2011 06:28 PM
New Gauge Cluster Background IMAPYRO Pre-2005 V6 Mustang 3 04-14-2008 05:44 PM
2001 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 5 12-10-2005 12:26 PM
mach 1 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 13 01-22-2005 10:51 PM
99-04 GT Gauge Cluster > '02 V6?? mattstang Mustang Audio & Video 8 12-15-2003 08:13 AM
12:58 AM
