starting problems need help - Mustang Evolution
Old 03-12-2011, 09:05 AM   #1
I just did a clutch and rear main seal put everything back together and no solenoid click when I tried to start it. Checked my clutch switch and all of my leads to the starter. Was working before I dropped the tranny. Any ideas or input would be greatly appreciated. I just want to drive been a month now since I bought it only driven 100 miles. Plz help. Thank you.
HaulinTwinz is offline   Reply With Quote
Old 03-15-2011, 01:32 AM   #2
Damn. This is the second thread you started about problems. I feel for you. All I wanna do is drive too. I have no idea on where to even start. Good luck and I hope you get into the cockpit pronto
Built 2 Last TTT
Old 03-15-2011, 01:02 PM   #3
Blustreek's Avatar
Region: Hawaii
Re: starting problems need help
Originally Posted by haulintwinz View Post
i just did a clutch and rear main seal put everything back together and no solenoid click when i tried to start it. Checked my clutch switch and all of my leads to the starter. Was working before i dropped the tranny. Any ideas or input would be greatly appreciated. I just want to drive been a month now since i bought it only driven 100 miles. Plz help. Thank you.
go back and check all ur connections again bro.be sure ur battery
has been load tested (fully chrgd.). Because the batt. Can read 12v
and still be bad w/a shorted cell having insufficient amps to op starting system.don't forget to test ur fuses too (u/h junc.box &
kick pnl. Fs.). Chk.continuity at all break points and splices,even all ur chassis ground points too.also get that starter tested and make sure ur motor turns over and not ceased or restricted in any way.remember you need a reliable pwr. Src. And efficient ground to make all work electronically,good mech. Op. Too.oh and check ur ignition switch cycle key.i assume you have lights on at i/p cluster and chime is op? Any other questions plz. Ask and i'll help you guy,good luck! Blustrk-
my 5.0 as of now is outta commission! Resto in progress,motor is getting an attitude change now and the same for the rest of the car. 1994 gt coupe hard top-full auto w/stall!
Blustreek is offline   Reply With Quote
Old 03-19-2011, 04:22 PM   #4
Thanks bro I figured it was a wire connector that I forgot to plug back in over the clutch pedal. Stoked that it runs again. Better than before and I still have to do the normal stuff plugs, cap, and tune up. No more 20 sec quarters with a old man in a s2000 beating me. Ha
Old 03-28-2011, 04:54 PM   #5
Blustreek's Avatar
Region: Hawaii
Hey we all have our trials! Glad to help.NOW GO CHURN RUBBER AND WIPE THAT GRIN OFF OF THAT S2000'S OWNERS FACE!!
New owner, 2002 Mustang starting problems skelaw Pre-2005 V6 Mustang 6 02-22-2011 06:57 PM
Starting problems! 99 SVT Cobra 1996-2004 Mustang GT 2 01-10-2010 04:47 PM
1989 5.0 starting problems tellico40 1979-1995 Mustang GT 5 10-19-2006 05:21 PM
Starting Problems Zak Attack 1979-1995 Mustang GT 16 05-17-2006 07:54 PM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 02:17 PM
04:13 PM
