Explorer intake - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 03-18-2011, 12:51 PM   #1
Albaraptor's Avatar
Albaraptor is unknown around these parts
Explorer intake
Is it worth putting a explorer intake on my mustang? How much hp gain am I looking at?
Albaraptor is offline
Old 03-18-2011, 01:03 PM   #2
stampde's Avatar
stampde is unknown around these parts
Re: Explorer intake
ITS the same as the Cobra intake !!!! if you have no other mods probably 10 -15 hp
but as you make more mods it will make more power / heads , cam etc ....
2006 Tungsten grey v6 Pony package
stampde is offline
Old 03-20-2011, 08:59 AM   #3
Dtw90lx is unknown around these parts
I have a mountaineer my wife drives I'm about to do a head and intake swap put my stock stang stuff on her car
Dtw90lx is offline
Old 03-22-2011, 10:29 PM   #4
Fstfoxx is unknown around these parts
It gives u a little more horsepower, but then u'll just have the same set up as everyone else, but understand if ur on a budget. And also some of those gt40 heads take speacial headers a little more pricier. Good luck on with the fox
Fstfoxx is offline
Old 03-26-2011, 01:39 PM   #5
How do you know if they take different headers? I always thought they were the same
Dtw90lx is offline
Old 04-07-2011, 09:59 AM   #6
Stang.racr's Avatar
Stang.racr is unknown around these parts
Re: Explorer intake
I run gt40p heads off a 98 explored they take different headers from bbk. My brother runs gt40 with aftermarket headers that he also run on his stock e7 heads . I also agree explored intake is well worth the money
Stang.racr is offline
Old 04-07-2011, 03:28 PM   #7
Would the heads off a 99 mountaineer be p heads?
Dtw90lx is offline
Old 04-07-2011, 03:30 PM   #8
Stang.racr's Avatar
Don't quote me on this but I think everything after 96 was
having a fine car that is slow is like having a hot girlfriend that won't put out!
Old 04-07-2011, 03:40 PM   #9
Senior Member
93CobraGuy is unknown around these parts
Re: Explorer intake
Yes
93CobraGuy is offline
Old 04-08-2011, 05:51 PM   #10
Titus Wadicus
svtlx's Avatar
svtlx is unknown around these parts
Re: Explorer intake
if you are on a budget.. you can get sum headers for about 100bucks from ebay for those gt40p heads.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
svtlx is offline
Old 04-08-2011, 09:26 PM   #11
I found some heads online they're pretty cheap for used gt40
Dtw90lx is offline
Old 04-09-2011, 08:01 AM   #12
Titus Wadicus
svtlx's Avatar
Re: Explorer intake
u know there's a difference between gt40 and gt40p right?
svtlx is offline
Old 04-09-2011, 08:04 AM   #13
Yes
Dtw90lx is offline
Closed Thread
Explorer Express SVTCOBRA Pre-2005 V6 Mustang 7 09-08-2010 04:55 PM
Internet Explorer 8 Screenshots Brent The Bar 14 07-09-2007 07:17 AM
Explorer pics Fishers Stang Pictures and Videos 11 08-16-2006 04:21 PM
no more explorer!!!! whipster24 Pictures and Videos 18 08-12-2005 06:38 AM
explorer ohc Bane- Pictures and Videos 14 10-11-2004 03:46 PM
03:40 PM
