car problem - Mustang Evolution
Old 03-19-2011, 06:46 PM   #1
car problem
My mustang will break up real bad over 2400 rpm for the first 4-5 miles and smell like it's running rich than starts running fine. If I'm not moving with no load on the car it revs fine. Any ideas? Money is tight so I would like some ideas before I start trying to fix it
Dtw90lx is offline   Reply With Quote
Old 03-19-2011, 06:48 PM   #2
Re: car problem
A $12 fuel filter might be a good idea.
93CobraGuy is offline   Reply With Quote
Old 03-19-2011, 06:52 PM   #3
I thought a fuel filter it would do it all the time. Maybe I will give it a try thanks for your opinion!
Old 03-19-2011, 06:58 PM   #4
Re: car problem
Definitely won't hurt anything.
Old 03-19-2011, 07:01 PM   #5
Yea I know of plugs getting hot and making a car do that can plugs do the opposite and run crappy until they get warm?
Old 03-19-2011, 07:11 PM   #6
Beav's Avatar
Re: car problem
Old plugs can run rough when first starting, but we are talking really high mileage plugs... If it has been awhile, you might want to change your plugs, another cheap fix...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 03-19-2011, 07:15 PM   #7
Well I just bought the car I was told motor was pretty fresh but who knows. It smells really rich also while running ****ty
Old 03-19-2011, 07:20 PM   #8
O2 sensor is going bad.
PETOM.biz TTT
Old 03-19-2011, 07:21 PM   #9
Re: car problem
What year is it? Carbed or FI?
Old 03-19-2011, 07:57 PM   #10
Blustreek's Avatar
Region: Hawaii
Re: car problem
Check ur spark plugs for condition and gapping.Check all emission system components for vacuum leaks.All intake too.See if PCV valve is sticking or stuck if so change it .Test for faulty or weak ignition coil,components.Is fuel pump old? Problem could be there too,inside fuel tank.Has ignition timing been messed with? check. Good luck! hope this helps you budd.Aloha from Hawaii! Blustreek aka Dean.
Blustreek is offline   Reply With Quote
Old 03-19-2011, 08:07 PM   #11
Thanks alot I tried to check the timing but the previous owner painted the balancer so I can't read it haven't had the time to crawl under it to mark it. Thanks for the help
Old 03-19-2011, 08:08 PM   #12
The car is a 90 efi. Wouldn't the o2 throw a code?
Old 03-19-2011, 08:17 PM   #13
Re: car problem
Yeah, it would.
Old 03-19-2011, 08:19 PM   #14
That's what I thought. Kinda makes it's difficult because I didn't do any of the work to the car myself it doesn't have much just msd iginition cold air built rear pro 5.0 shifter
Old 03-19-2011, 08:23 PM   #15
If there is no codes. Chances are it's fuel or fire. Fuel filter in the morning. First step.
Alscobra is offline   Reply With Quote
Old 03-19-2011, 08:33 PM   #16
Take a pic of that ignition system too. Might be that. Pop the dist. cap loose and look under it too. Check for moisture and any tracing.
Old 03-19-2011, 08:41 PM   #17
Ya..I dunno guys. If the light on on I dunno
PETOM.biz TTT
Old 03-19-2011, 08:55 PM   #18
Re: car problem
ok thanks i will check it out tomorrow. thought it was werid because every day i leave to go to work it starts running fine at the same exact place and mile on the road no matter how long i let it sit and warm up for. doesnt seem to take as long to run ok when its warmer out
Old 03-20-2011, 08:32 AM   #19
06mustangmike's Avatar
Re: car problem
could it have anything to do with fuel?
06mustangmike is offline   Reply With Quote
Old 03-20-2011, 08:34 AM   #20
I'm going to put a new fuel filter in it see what that does
Old 03-26-2011, 05:48 PM   #21
Blustreek's Avatar
Region: Hawaii
Re: car problem
I just noticed another thing could be acting up in ur ignition system.It could also be tied to a faulty MSD ign.box,harnemss or bad grounding circuit.Remember ur MSD is a spark enhancer or spark databank,Signal amplifier.A series of weak sparks can cause break up.
Old 03-27-2011, 09:12 PM   #22
Ok thanks alot I will look into my life has been crazy hectic so haven't had any time for my stang
Car Problem, What do you guys think? braumab 2005-2010 Mustang GT 11 12-04-2008 01:07 PM
Car Cutting off Problem SC_STEEDA Pre-2005 V6 Mustang 4 10-26-2007 12:44 PM
Car problems continue,Speedo' problem Dark02Pony Pre-2005 V6 Mustang 4 09-22-2005 12:19 PM
Car wash problem.... douGT The Bar 15 03-28-2005 12:27 PM
12:05 AM
