Trans noise - Mustang Evolution
Old 03-22-2011, 05:26 PM   #1
Trans noise
Hi everyone. I have an issue with my 89 gt. It has a 3550 box in it. Everytime I cruise between 70-75 there is this horrific whine coming from the trans. Any help would be greatly appreciated. It does not whine like that at any other speed and that is in 5th.
MSF1981 is offline   Reply With Quote
Old 03-25-2011, 12:22 AM   #2
Blustreek's Avatar
Region: Hawaii
Re: Trans noise
When was the last time you serviced ur transmission fluid? Try draining old fluid out completely and pump in fresh tranny fluid specified for that standard trans. Do you know for sure it's coming from ur trans. and not anywhere else in ur drive line like ur U-joint or ring and pinion in the rearend? Only in 5th gear would mean Overdrive,gear might be worned out,too far a gap between can give play and humm and whine.
Blustreek is offline   Reply With Quote
Old 03-25-2011, 07:15 AM   #3
Re: Trans noise
part of it is the shifter transferring the noise probably you can put some dynomat around the shifter base to try and get rid of a little of it.
Old 03-26-2011, 12:33 PM   #4
Blustreek's Avatar
Region: Hawaii
Re: Trans noise
True dat! Nrg transfer from shifter bracket into cabin.
Old 03-26-2011, 07:24 PM   #5
Thanks to everyone for the advice. It is probably do for a fluid change. I'll also look to put some matting there to cut down on road noise
Trans Blackpony Classic Mustangs 6 01-01-2011 09:40 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
New 5.0L Trans. TBone 1979-1995 Mustang GT 0 05-04-2004 08:47 PM
trans am.... lowflyn Pre-2005 V6 Mustang 7 01-06-2004 09:28 PM
Trans Am GT??? .:DarkEntity:. The Bar 10 09-17-2003 03:17 PM
07:36 PM
