Clutch still turns tranny in neutral - Mustang Evolution
Old 03-22-2011, 05:39 PM   #1
i got my clutch in finally and to make sure there was no leak before i went ahead with the exaust and driveshaft.. i started it up let it run for a sec to make sure no leaks ... none so far ... then i went threw and checked the gears and noticed the speedo still moved while in neutral just like the rest of the gear didnt know if it was because i didnt have my drive shaft on or if something else is going on ... i recently put a rear main seal on and found out after trial and error my crank was drill all the way threw so it leak oil ... fixed that problem but wen i removed the clutch it had to black hot spots??? didnt know if this was brake in friction or if something was wrong lined it up with the tool and toqued it down ne ideas ??
If both wheels aint spinning then i aint grinning
Justbust1n is offline   Reply With Quote
Old 03-23-2011, 08:36 AM   #2
stampde's Avatar
Re: Clutch still turns tranny in neutral
well if you went through the gears then to neutral the trans was probably still spinning since you had no drive shaft bolted up to drag it down , did it eventually stop ?
2011 GT Auto
Old 03-26-2011, 03:11 PM   #3
Blustreek's Avatar
Region: Hawaii
That means ur not in neutral. You need to drop that tranny and have a look inside. Apparently ur clutch is operative,Does the speedo stop registering when you push clutch in?If it does than you really know it's enaging which it shouldn't in neutral.Problem is in the trans.
Blustreek is offline   Reply With Quote
Old 03-26-2011, 08:21 PM   #4
Just put it together man. Chances are with no driveshaft connected may spin a little. The input shaft is still riding in the pilot bearing which is spinning. Shouldn't be enough to make wheels spin. In neutral parts are still spinning in there.
Alscobra is offline   Reply With Quote
I Need Help....clutch/tranny advice vinnie7009 1979-1995 Mustang GT 4 07-13-2008 09:59 PM
01 GT T45 tranny/flywheel/clutch/shifter for sale whipster24 Mustang Parts for Sale and Wanted 0 08-24-2007 10:38 PM
so as it turns out, God DOES hate me jimmy_beaner The Bar 14 06-15-2005 09:20 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
Someone turns 21 today....... Brent The Bar 8 04-19-2004 07:31 AM
05:41 AM
