fuel tank filler neck seal advice. - Mustang Evolution
Old 03-25-2011, 12:36 AM   #1
Gotta replace the seal around the filler neck where it goes into the tank. Is there any other way than dropping the whole tank? Just curious if there might be a faster way? Its on a sn95 any help is always appreciated mustang evolution folks. Thanks again
HaulinTwinz is offline   Reply With Quote
Old 03-25-2011, 12:41 AM   #2
Las0mbra's Avatar
Idk how much access you'd have if you did this, but pull back the side covering on the right side of the trunk and you'll see the filler neck itself.
Old 03-25-2011, 02:15 AM   #3
1ijack's Avatar
Send a message via Yahoo to 1ijack
I can answer this It is really simple you need to drop the tank about 3 inches. Take off the side covering from inside the trunk and unscrew the cover and the fuel filler line from quarter panel. Pull up on the filler tube but be careful not to break the end off in the tank. Then replace filler seal and put back together
It took me about an hour to do and it works great. No leaks buy it from ford it is a new design.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 03-25-2011, 08:31 AM   #4
There is nothing inside the trunk. Its on a 94 and the neck goes from the tank to the Filler door on The outside of the car
Old 03-25-2011, 09:49 AM   #5
SaleenFiend's Avatar
Re: fuel tank filler neck seal advice.
Yea, I've never been able to see the filler from inside the trunk
Old 03-25-2011, 12:07 PM   #6
Las0mbra's Avatar
You have to pull back the hard lining along the side, I went in from my car, not the trunk.
Old 03-25-2011, 12:18 PM   #7
I understand what u mean but I'm pretty sure there has always been a body panel in the way. It's been a while and I don't have a car to look at.
*From the Android App
Old 03-25-2011, 12:24 PM   #8
Rosco's Avatar
I did this recently to my 98. I don't know if the fueling setup differs but I didn't need to drop the tank at all. I pealed back the covering in the trunk off the side to get access to the hose from behind and removed the fuel door. Then I had to remove a few bolts on the hose that help secure it into the tank. After that I used lots of angles and leverage to push the hose out of the tank upwards to where the hose was sticking out of the side of the car. Then I just replaced the seal and repeated the process reversibly. It took about a half hour of laying under the trunk and leaning in the trunk.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 03-25-2011, 02:18 PM   #9
Las0mbra's Avatar
Here
Old 03-25-2011, 07:21 PM   #10
Rosco's Avatar
See with that back I just shimmied the hose out and replaced the seal.
Old 03-26-2011, 09:59 PM   #11
SleepingStang's Avatar
I did this awhile back cause mine was leaking upon fill up. I dropped the tank, not fully though. I loosened the strap on the driver side and removed the strap on the passenger side. Then using a floor jack I lowered the tank till the filler tube could be wiggled out. Pulled the old seal and popped in the new one. I would caution you though, there is alot of dirt in that area if your tank has not been dropped, so before you remove anything clean so it doesn't contaminate today's expensive gas or ruin your pump. All in all it was not a horrible job but there is not a ton of room to work, and watch your electrical connections on top of the tank. Good luck.
SleepingStang is offline   Reply With Quote
Old 03-26-2011, 10:01 PM   #12
Sorry forgot to mention, my car is a 92 LX.
Big Problem with the gas tank/filler neck/fuel etc runvsofthisbull Pre-2005 V6 Mustang 4 08-16-2010 08:30 PM
Possibly Fuel Leak, Gas Tank Mustang1804 1996-2004 Mustang GT 33 04-03-2010 09:46 PM
Fuel filler tube, grommet? Otlaw80 Pre-2005 V6 Mustang 4 05-12-2009 11:41 AM
Fuel Tank/filler neck Scut95 1979-1995 Mustang GT 8 11-26-2008 01:15 PM
fuel tank and radiator issues... mustangmare Pre-2005 V6 Mustang 1 11-01-2004 07:09 PM
04:28 AM
