What Torque Converter? - Mustang Evolution
Old 03-26-2011, 06:58 PM   #1
WhiteCobra94's Avatar
What size stall does the trickflow stage 1 cam require? Thanks for your help!!!
Old 03-27-2011, 11:15 AM   #2
I also have 4.10 gears
Old 03-28-2011, 02:30 PM   #3
Blustreek's Avatar
Region: Hawaii
Re: What Torque Converter?
According to summit racing I believe it's a 2500-2700rpm stall.The higher the better for optimum hole shot power.
Blustreek is offline   Reply With Quote
Old 03-29-2011, 06:59 AM   #4
Now I'm only gonna have about 300rwhp if I went closer to 2700-3000 would that be to high or should I stick with the correct size for my cam and gears?
Old 03-29-2011, 07:46 AM   #5
Titus Wadicus
svtlx's Avatar
if its gonna be a street car i wouldnt go over 3000.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-29-2011, 08:58 AM   #6
Yea it's gonna be a street car, something fun to drive !
Old 03-29-2011, 07:27 PM   #7
Blustreek's Avatar
Region: Hawaii
Bro just stick to the specs I gave you.See every Camshaft has a set profile of it's operating range (RPM's) where it'll make the most power specified for your engine.
Going upward to 3000 is starting point of range for your cam profile but you wanna give your engine some lead way to preload.
Torque Converter joeysull Classic Mustangs 4 06-08-2010 05:33 PM
torque converter b's stang 2005-2010 Mustang GT 1 03-04-2010 02:43 PM
Torque converter DarkShadow Pre-2005 V6 Mustang 5 05-07-2006 07:36 AM
torque converter tealstangman 1996-2004 Mustang GT 4 04-06-2006 05:51 PM
Torque converter cuban3jumper Pre-2005 V6 Mustang 5 07-08-2004 08:13 PM
01:10 PM
