Opinion On Methanol Injection - Mustang Evolution
Old 03-29-2011, 05:55 PM   #1
gixxer007's Avatar
I am about to order a snow performance methanol for my supercharged fox body. It was going to get the stage 2 unit they offer. is this the right thing to do and has anyone had any good or bad issues with them. If I am reading it right that one is good for up to I think 18 LBS of boost which is plenty for me.
Or am I going in the wrong direction for a lower boost car. Just want to be safe from detonation issues and a little more helper HP.
Any advice or heads up would be great.
Thank You
gixxer007 is offline   Reply With Quote
Old 03-29-2011, 10:27 PM   #2
1ijack's Avatar
Send a message via Yahoo to 1ijack
I was thinking about the same for a juiced car which water meth I was told would help me.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 03-30-2011, 07:35 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Opinion On Methanol Injection
Thank You
how many psi are you running now? what heads do you have on your car? do you know the cumbustion chamber size/compression ratio? are you running an intercooler? need a few facts to help answer your question.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-30-2011, 10:50 AM   #4
why not use an intercooler or are you and you want extra cooling?
Methanol injected N/A? 67mustang97 1996-2004 Mustang GT 2 10-19-2009 07:28 PM
Meth injection iwannagofast 1996-2004 Mustang GT 9 05-01-2009 04:55 PM
water methanol injection (snow kit) k28gt 1996-2004 Mustang GT 0 03-01-2008 01:42 PM
snow performance and others(methanol inj) sporter 2005-2010 Mustang GT 17 05-29-2007 04:02 PM
03:55 AM
