auto trans for a 94 gt - Mustang Evolution
Old 03-31-2011, 09:31 PM   #1
workmail21's Avatar
I was wondering if u guys can tell me if there's an auto trans that can handle 500hp and where I could get it I've been looking but can't find anything that can handle that much
workmail21 is offline   Reply With Quote
Old 03-31-2011, 09:35 PM   #2
Re: auto trans for a 94 gt
Auto's can handle some pretty big power. Now, I'm not an auto guy, so don't read too far into what I'm saying, but check some websites for a built C4 or C6 trans.
93CobraGuy is offline   Reply With Quote
Old 03-31-2011, 09:40 PM   #3
Brett Greene's Avatar
My friend has a 94 with 450 rwhp and stock Tranny. Hasn't had a problem yet and it's and Auto
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-01-2011, 03:06 AM   #4
workmail21's Avatar
Ok sounds good I was just a little worried I'm putting a new motor in and I didn't wanna burn up my tranny ill look in to those tho thanks
Old 04-01-2011, 03:17 AM   #5
My friend chad has an 86 fox converted to mass air,gt 40 heads punched out .030. Over 400 rwhp on a stock aode tranny. He drags races every weekend at the track and countless street races. With no tranny issues at all.
PETOM.biz TTT
Old 04-07-2011, 04:38 AM   #6
Hey new to the forums here. What I did with mine was a shift kit and a torque converter. I don't think their bullet proof.
But I heard people swapping for the 2003 auto I think from the v6's. And they hold up pretty good.
Jamrock09 is offline   Reply With Quote
Old 04-07-2011, 12:06 PM   #7
Stang.racr's Avatar
The weakest link will always be the first to go, I have torn up aods with cam and bolt on cars but have seen them takes years of abuse on hci cars and hold up, your best bet is a c4 or even glide if it don't see alot of highway, but run it till it goes out, but back to the weakest link subject it could last a couple years on highway or two passes if u try to run slicks and and roast em at the track
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-07-2011, 09:27 PM   #8
workmail21's Avatar
Well its my daily drive so it sees highway miles
Old 04-08-2011, 12:02 PM   #9
Stang.racr's Avatar
Pa aode with tci torque converter should hold pretty good. Around 1700 new in late model restoration I believe
Old 04-08-2011, 05:44 PM   #10
Titus Wadicus
svtlx's Avatar
trans depot
727-868-9462
they make aod..aode..and g.m. trannys as well. my aod is rated for 700hp. i have a 2400 stall on it, and it is an absolute nasty beasty *** trans. it's been in my car for 3yrs with bolt ons and a blower. it's manual/auto shift valve body, kevlar clutches, upgrade reverse drum, upgrade sprag.. lotsa stuff. u get a warranty, and ppl willing to still talk to u 36 months after intial purchase.
i think they have prices from 12-1800
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-08-2011, 10:25 PM   #11
workmail21's Avatar
Originally Posted by svtlx
trans depot
727-868-9462
What is a manual/auto shift?
Will ur trans bolt in to a 94 gt conv?
Old 04-09-2011, 08:26 AM   #12
Titus Wadicus
svtlx's Avatar
it means u can put it in drive/overdrive and it will shift itself. or u can shift it manualy and it will hold the gear it's in, also u wont hurt it doing prolonged manual shifting like u will with a stock aod. a long time ago, when u bought a manual shift valve body for an auto..u had to manualy shift it all the time (upshift and downshift) and you didnt have the option of the trans shifting by itself.
u can do aod or aod(e) for your car. i would suggest you do an aode. you would have to ad a t.v. cable to run an aod which would require modifying your throttle bracket.
the advantage of an aod is the predictability and consitency in shifting. the computer plays no part in the trannys operation unlike the aode.
again, i would suggest u put in wut came out for simplicity of install (the aode). talk to the ppl at trans depot and they can help point u in the right direction. i believe they are out of lakeland, fl. also there is a company called "road runner converters" out of pheonix, az. i deal with that makes really nice stall converters... lock-up and non lock up for aode and aod
Old 04-12-2011, 05:59 AM   #13
Blustreek's Avatar
Region: Hawaii
See tci.com & bowlertrans.com for now
Blustreek is offline   Reply With Quote
Old 04-13-2011, 11:00 AM   #14
lentech is the only way to go as far as AOD's/4r70's go
iamdat is offline   Reply With Quote
Old 04-16-2011, 10:31 PM   #15
Redneck c4
Z06 eater is offline   Reply With Quote
97 Stang Auto Trans Problem Stealth Pre-2005 V6 Mustang 5 04-20-2009 07:10 AM
99 GT Auto Trans Problem hawks05 1996-2004 Mustang GT 2 02-24-2009 04:50 PM
00 gt auto trans issues cue59 1996-2004 Mustang GT 9 02-17-2009 04:12 PM
v6 and v8 auto trans mustangmichael 1996-2004 Mustang GT 4 09-19-2006 07:17 PM
3.8 EFI V6 and auto trans... BK Meyers Mustang Parts for Sale and Wanted 0 07-11-2004 07:27 AM
07:52 AM
