Looks like i need my block bored - Mustang Evolution
Old 04-02-2011, 01:27 AM   #1
Chris01's Avatar
i bought a 1992 mustang about a month ago and decides to put some heads cam and intake and was going to replace the main bearings but now that i have the scratch i might be getting the block bored .030 over. i trying honing it a little to get rid some of it but im not sure about it. I could get a junk yard block but it might be just as expensive to get the block and clean it up and then something might also be wrong with it also
ID:	25627   Click image for larger version
Chris01 is offline   Reply With Quote
Old 04-02-2011, 06:34 AM   #2
SaleenFiend's Avatar
Re: Looks like i need my block bored
Jesus Christ that's terrible. Does the piston have any markings?
Old 04-02-2011, 10:54 AM   #3
Chris01's Avatar
No the piston is fine and the rings where intact.... I might put the block back together somewhat to see if I still get good compression on cylinder
Old 04-02-2011, 11:00 AM   #4
Tib
Tib's Avatar
Wow that sucks do you know what caused it?
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 04-02-2011, 11:06 AM   #5
Kinda what I was getting at.. that's wicked.
Old 04-02-2011, 11:26 AM   #6
Chris01's Avatar
I have no idea how it happen. I wish I did know.
Old 04-02-2011, 11:35 AM   #7
It's an imperfection in one of your rings. Probably where they are cut. There was or is a burr at the end of one. Slight raised edge. It's a harder steel or moly material than your block. Can you feel that groove or just see it? Can't tell from the pics if it is dug into.
Alscobra is offline   Reply With Quote
Old 04-02-2011, 11:49 AM   #8
Chris01's Avatar
Yea u can feel it. I have checked the top ring but I never did check the 2nd or oil ring yet.. I'm going to check it and take some pics if there is something wrong
Old 04-02-2011, 11:56 AM   #9
They have been in there for 20 years man. There's no point now. Option 1: put it back together and drive it like you stole it. May burn a little oil but compression loss shouldn't be too bad. Option 2: build now or buy a rotating assy. I prefer buying a short block. Usually come out a lot cheaper in the long run. Good luck.
Old 04-02-2011, 01:26 PM   #10
Chris01's Avatar
Im just going to run it as it is to see how it does.. Its my fun toy to tinker with
Old 04-02-2011, 10:19 PM   #11
K...go to napa and buy a couple bottles of lubro-moly. It will fill that scratch and be un-noticeable. It amazing stuff
PETOM.biz TTT
Old 04-02-2011, 11:27 PM   #12
Chris01's Avatar
What does that stuff actually do
Old 04-03-2011, 01:17 AM   #13
K with the heat and friction of the moving parts it fills all the microscopic imperfections in the metal creating a perfectly smooth metal surface. Honestly bro google it. There is a wealth of info on it. In a market of snake oil that stuff actually lives up to it's claims. It is found in royal purple and red line oils as well. Or go to bob is the oil guy forum. There are about 100 threads with guys who have used and commented. All with positive results. I put it in the mustang and now get about 50 more miles per tank. In my truck was about 70 miles per tank. The first thing I noticed was my idle increased about 200 rpm. So the ecu was putting in the same amount of fuel but the friction was reduced so the idle went up. It returned to normal after about 3 tanks because of the ecu's adaptive learning but honestly the stuff works. Try it. It's only 5 bucks. It will pay for itself in fuel alone.
PETOM.biz TTT
Where to get a 4.2 block Zebs5408 Pre-2005 V6 Mustang 10 02-27-2010 01:46 PM
5.0 on a 4.6 block. DaDant! 1996-2004 Mustang GT 2 02-06-2009 08:35 PM
4.6L Block hawks05 Mustang Parts for Sale and Wanted 1 03-30-2005 01:16 AM
4.2 Block n8r Pre-2005 V6 Mustang 5 06-12-2004 10:10 AM
91 Block the same as 94+? Brent Pre-2005 V6 Mustang 10 11-07-2003 08:13 AM
05:37 PM
