How does this sound for a swap? - Mustang Evolution
Old 04-02-2011, 10:45 AM   #1
NeedSomeMods's Avatar
The idea is to turn my base 1994 'stang into a 5.0l with a manual.
I found a 5.0l motor, 5speed transmission, wiring, and computer, with 124k miles on it for $600 on craigslist.
It's coming out of a '90 GT.
What do you guys think?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-02-2011, 02:13 PM   #2
BrKu789's Avatar
Send a message via AIM to BrKu789
It's a good price but you always got to be skeptical when the motor has that many miles on it. It sure beats the price of building your own though! But manual for sure is the way to go!
NEXT TO SEX, MY MUSTANG IS BEST
BrKu789 is offline   Reply With Quote
Old 04-02-2011, 03:26 PM   #3
Re: How does this sound for a swap?
Poster said that he wrecked the car and that motor/trans performed perfectly before removed from the car.
Still not sure though...may just wait until I really figure out what I want to do and what I want to use for it.
When I find the right deal, and I have the money, I'll know
Patience is key.
2000 V6 - RIP
The '94 -
Old 04-07-2011, 01:08 PM   #4
Stang.racr's Avatar
From what I have heard u gotta get a wiring harness for a 94 or 95 to make it work. I know the intake will need a elbow for it cause it has like a 45 in the 94 95. The oil pans are different. And the wiring harness are different. The 92 uses a two plug 75 amp alternator and the 94-95 uses a one plug 130. U can wire in what's different though cause I am running a 95 alternator on my car now though it did take my engineering skills lol
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-08-2011, 06:04 PM   #5
Titus Wadicus
svtlx's Avatar
94-95gt harness... and you can use a 87-93 harness, itsa lil more work but it will go in.
the oil pans are not different, they are the same... the timining cover is different.
if you use your foxbody throttle cable (cruise cable..optional) you can use the 87-93 intake set-up and accessory drives/bracketry. ive seen foxbody motor set-ups all the way up to '03
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-08-2011, 06:16 PM   #6
Thanks everyone. got some useful information andhopefully I can find a wrecked 94-95 Gt to make it simpler when the time comes. This project is taking the backseat for now though.
Thanks again guys.
2000 V6 - RIP
The '94 -
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
i don't like this sound, but what is it? Sassa Massa 1979-1995 Mustang GT 10 07-31-2006 11:02 AM
how would this sound? a00v6stang Pre-2005 V6 Mustang 7 02-16-2006 09:08 PM
How does this sound? Dom Pre-2005 V6 Mustang 30 09-23-2005 07:36 PM
No sound 97conv6 Mustang Audio & Video 7 01-28-2005 09:15 PM
05:59 PM
