possible heads problem? - Mustang Evolution
Old 04-03-2011, 03:38 PM   #1
Ok I'm going to be as specific as possible here. Just bought the car, guy told me he had the engine rebuilt. Well I was putting some oil in it, then started it up and it started making a really loud knocking sound from the passenger side valve cover. Now this is a really loud knock, sounded like someone was punching from the inside of the valve cover. I pulled off the valve cover and it did seem like a few of the rocker arms were loose. They were tight on the fulcrum nut, but still moved around quite a bit. I'm taking the heads off this weekend, but just wanted to know the heads are the problem like I'm thinking or if its something else. By the way its an 82, so if you guys could help me out I will really appreciate it
chickenplucker2 is offline   Reply With Quote
Old 04-04-2011, 09:09 PM   #2
Um any ideas?
Old 04-04-2011, 09:12 PM   #3
K the pushrod guy to talk to is svtlx and I haven't seen him on lately. Alscobra is a mechanic too so maybe pm him
Old 04-07-2011, 09:56 AM   #4
Stang.racr's Avatar
Re: possible heads problem?
It could be a aftermarket rocker just hitting the valve cover. But regardless u gotta take it apart anyway so put better parts back into it. Upgrade the valve springs and if u got stock cam u could throw some 1.7 rr on it and wake that pony up
Stang.racr is offline   Reply With Quote
Old 04-07-2011, 10:13 AM   #5
wereKEV's Avatar
aounds like a rocker hitting the inside of valve cover or a bad piston or valve.
wereKEV is offline   Reply With Quote
Old 04-07-2011, 03:43 PM   #6
Ok sweet, gonna be pulling it apart this weekend, just hope its nothing to do with the pistons, or she might be sitting for a little while ill keep you guys posted on it
Old 04-07-2011, 03:44 PM   #7
Oh any suggestions for what I should throw back in the heads, Just wanna make sure I get the right setup in her
Old 04-08-2011, 04:09 PM   #8
SleepingStang's Avatar
Not sure what lifters were in the car when it was rebuilt but could also be that one of the lifters could have collapsed if they are hydraulic and also could be incorrect pushrod length if the heads and block were decked when rebuilt. Just a few suggestions. When I did my build I used a pushrod length checker I got from summit racing and then ordered a set of FRPP rods based off the length checker.
SleepingStang is offline   Reply With Quote
Old 04-10-2011, 12:10 PM   #9
Ok here's the update, seems one of the pushrods failed, the little ball at the end that touches the lifter is gone... now its time to find where it went...
heads spading756 1979-1995 Mustang GT 3 02-25-2011 05:37 PM
3.8 Heads kirbo7106 Pre-2005 V6 Mustang 5 01-28-2011 10:12 PM
Need help choosing heads and fixing dash light problem Qwik Four Six 1979-1995 Mustang GT 11 12-31-2010 02:31 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
05:17 PM
