Rear and or drive shaft noises - Mustang Evolution
Old 04-06-2011, 11:37 AM   #1
Mean green 91's Avatar
Well I have a noise in the rear and a vibration when I reach 50 mph. I would like to have some advice on what you guys and or lady's think it could be. The car is a 1991 GT Thank you.
Mean green 91 is offline   Reply With Quote
Old 04-06-2011, 12:11 PM   #2
Brett Greene's Avatar
Have you replaced the drive shaft? I had a slightly twisted stock one and it did that. Replaces it with an aluminum one and it went away
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-06-2011, 01:09 PM   #3
bbunt302's Avatar
Re: Rear and or drive shaft noises
It could be the driveshaft is damaged or that your U-joints are worn. A less likely problem is that something is busted in your differential. You may want to check to your differential fluid though.
Scary stuff.
Old 04-06-2011, 01:26 PM   #4
Thanks for the advice going to check it out before more problems come about.
Old 04-06-2011, 03:01 PM   #5
Another thing you can try is rotating the driveshaft 90° at a time and see if the vibration either goes away or gets better.
93CobraGuy is offline   Reply With Quote
Old 04-06-2011, 05:00 PM   #6
gixxer007's Avatar
Yea try the rotating suggestion first if no luck buy a complete alum one it will help for sure you still need to rotate that one also to get it right.
gixxer007 is offline   Reply With Quote
Old 04-06-2011, 06:03 PM   #7
Plus 1.
Old 04-07-2011, 05:28 PM   #8
Thanks guys rotating the drive shaft worked but still going to buy an aluminum drive shaft along with sub frame connecters.
Old 04-07-2011, 05:34 PM   #9
Stang.racr's Avatar
Pay the extra money and get a drive shaft loop. They are cheap insurance to hurting you or others possibly. That being said my cheap *** needs to buy one
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-07-2011, 05:41 PM   #10
Drive shaft loop will be brought thanks for the reminder.
driveshaft noises? HaulinTwinz 1979-1995 Mustang GT 1 04-07-2011 12:10 PM
Aluminum Drive Shaft? Paincake1 Pre-2005 V6 Mustang 5 01-22-2009 05:41 PM
FS: NEW IN BOX Drive shaft loop Loco Mustang Parts for Sale and Wanted 0 11-27-2005 09:05 AM
tranny noises? MustangNewB Pre-2005 V6 Mustang 7 05-25-2004 10:24 AM
Got my aluminum Drive shaft and Bullitt pedals WooHoo!!! Danger Dude Pre-2005 V6 Mustang 13 12-09-2003 07:57 AM
10:21 PM
