Problem! Help please! - Mustang Evolution
Old 04-09-2011, 12:25 AM   #1
I have a 1995 mustang gt and it has the current problem of turning on and turning off right away, without the gas held down.
Anyone have this problem before? TIA
Mustang403 is offline   Reply With Quote
Old 04-09-2011, 12:33 AM   #2
Be a little more specific. Does it start and then die? Was anything done to it lately?
Alscobra is offline   Reply With Quote
Old 04-09-2011, 11:29 AM   #3
Stang.racr's Avatar
X2 on what he said. Could be alot of things. My dd did that, as soon as I cranked it it would run about two seconds and die, it was the iac was disconnected by the throttle body
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-09-2011, 11:35 AM   #4
To be more specific, I turn it on then it shuts off right away. Weird though started fine this morning. : /
Old 04-09-2011, 11:36 AM   #5
Also full exhaust new o2 sensors and a cai.
Old 04-09-2011, 12:25 PM   #6
Mass air flow sensor may be backwards or unplugged. Mass airflow sensor will do that. Leak after the MAF will do it too.
Old 04-09-2011, 12:41 PM   #7
The MAF is ok, I may have a leak around my IAT sensor. So I am looking into that.
Old 04-09-2011, 05:26 PM   #8
bbunt302's Avatar
Re: Problem! Help please!
Does your CAI require you to the oil filter? If so, have you cleaned the MAF since oiling your filter?
Scary stuff.
Old 04-09-2011, 05:38 PM   #9
Stang.racr's Avatar
With throttle body cleaner.
Old 04-09-2011, 05:40 PM   #10
Electronic cleaner is best. Tb/carb cleaners tend to have silicone in them to lube the moving parts leaving a residue behind.
Old 04-09-2011, 07:39 PM   #11
Stang.racr's Avatar
Sounds good iv never cleaned maf. I cleanses iac with throttle body cleaner but I'll stick with electrical cleaner for that kinda stuff
03 GT...another problem Zebs5408 1996-2004 Mustang GT 10 03-07-2011 07:33 AM
Anyone else have this problem? LuvMyMustangGT 1996-2004 Mustang GT 47 02-26-2011 03:26 PM
00 v6 problem!! will_0828 Pre-2005 V6 Mustang 11 12-23-2009 06:51 AM
Problem.. lowflyn Pre-2005 V6 Mustang 15 07-25-2005 12:52 PM
11:14 PM
