rocker arm help - Mustang Evolution
Old 08-04-2007, 03:37 PM   #1
rocker arm help
Ok i have a 95 gt with 331 stroker and my rocker arms sound like they are loose. Can I just torque them down to specs or do i have to place each cylinder at top dead center first.
thanks
rbhasychak is offline   Reply With Quote
Old 08-05-2007, 10:46 AM   #2
Joel5.0's Avatar
Re: rocker arm help
The second one.....check the procedure....BTW, did you check the valve train geometry and installed the correct PR length?.....
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
Old 08-06-2007, 04:49 PM   #3
bullitt482's Avatar
Re: rocker arm help
Umm... That's for a pedestal mount rocker setup... I'm pretty sure that he doesn't have that kind of setup unless he is more hardcore than I think he is. And how do you "check" for valvetrain geometry?? You can pretty much use any close to stock pushrod if you are using a stud mount roller rocker and hydraulic lifters......
This is what I'm pretty sure your are looking for Adjusting Stud Mount Rockers
Actually, the only way to answer your question is to determine what kind of rockers you are using. Are you using the stock style stamped rockers, are you using stud mount roller rockers, are you using a pedestal mount rocker setup, are you still using hydraulic roller lifters??? We need more info to answer your question...
01 Bullitt
Old 08-13-2007, 09:44 PM   #4
silverstangboy's Avatar
Re: rocker arm help
actually bullitt you still have to check pushrod length with pedistal mount rockers, but you can only adjust using shims or planeing the mounts down. the problem is that the HRL will make up for about .030" s of "flub up" but after that things get nasty.
93 mustang notch
~450hp 331 stroker - Sold
Old 08-14-2007, 05:04 PM   #5
bullitt482's Avatar
Re: rocker arm help
I never said you weren't supposed to :dunno: My statements were based on a stock style setup.... Which I'm pretty sure this guy is running. Like I said, to answer any of his questions, we need more info...
01 Bullitt
Adjustable crane cam rocker arm problems ballajb 1979-1995 Mustang GT 8 11-04-2009 09:30 AM
Which female rocker do you think is the hottest? sonic04edge The Bar 21 08-04-2008 04:27 PM
springs and rocker arms tigerfan2771 Pre-2005 V6 Mustang 2 05-25-2008 08:27 PM
Rocker geometry kurt herold 1979-1995 Mustang GT 0 09-17-2005 11:30 AM
Rocker Geometry Tech RGR Pre-2005 V6 Mustang 3 03-22-2005 09:52 AM
12:34 PM
