help with new heads? - Mustang Evolution
Old 04-10-2011, 05:23 PM   #1
I want to get heads for my 91 lx. My engine is stock but i plan on getting a cam and other stuff. What do you recomend?
psycho5.0 is offline   Reply With Quote
Old 04-10-2011, 05:29 PM   #2
Stang.racr's Avatar
If u on a budget under a 1000 get u some gt40s or something. But I'm a big fan of trick flow twisted wedge and afr heads. Some trickflow 170s or 190s would wake that pony up with a matched intake
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-10-2011, 05:33 PM   #3
Would i have to make any piston modifications for either one?
Old 04-10-2011, 05:38 PM   #4
Stang.racr's Avatar
You shouldnt with a stock cam. Im pretty sure you'll be running 1.6 roller rockers so u outta be all good
Old 04-10-2011, 05:40 PM   #5
So i cant put cams if i upgrade the heads? If so whats better cams or heads?
Old 04-10-2011, 05:41 PM   #6
bbunt302's Avatar
Depends on the cam. You should always measure the piston to valve clearance though since every engine is slightly different.
If you're on a budget, Trick Flow has an entire heads, cam and intake package that is reasonably priced and is designed to work well together. It also comes with all the little things you need like gaskets and bolts.
Scary stuff.
Old 04-10-2011, 05:45 PM   #7
Stang.racr's Avatar
As he said. They five u everything u will need in one package. Sticking with the same brand is always better than putting 5 different brands on. Trick flow package runs around 2500 from late model restoration
Old 04-10-2011, 05:52 PM   #8
Sorry its my first 5.0. How do u measure the distance and how would you know if u need new pistons?
Old 04-10-2011, 08:04 PM   #9
Stang.racr's Avatar
Www.camshaftshop.com will explain it very good
which heads? chickenplucker2 1979-1995 Mustang GT 2 03-26-2011 03:52 PM
how can i tell if i have PI heads or not? redbird2289 1996-2004 Mustang GT 4 08-26-2009 08:56 PM
Heads upton7 Mustang Parts for Sale and Wanted 0 08-11-2009 10:51 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
heads 93stanger 1979-1995 Mustang GT 12 05-24-2006 08:05 PM
11:49 PM
