Headlight dash light switch problems - Mustang Evolution
Old 04-11-2011, 09:07 AM   #1
Mean green 91's Avatar
When I push my headlight switch all the way in only my headlights come on if I pull it back a little taillights come on and the same for my dash light switch got to play with it. Anyone ever have these problems?
Mean green 91 is offline   Reply With Quote
Old 04-11-2011, 09:17 AM   #2
A.K.A. Baby-D!
Re: Headlight dash light switch problems
i've been told that these are known for 'going out'. in my fox my headlight switch worked fine but when i would turn on the fog lights my headlights would blink every now and then causing some kind of short. if i played with the fog light switch it would stop. replaced the switches and i'm good to go now.
good luck and let us know what works for you
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 04-11-2011, 09:29 AM   #3
they are rather easy to replace, you can yank one from a pull a part junk yard. The hardest part is getting that stupid light knob off... major pain.. cant just pull it. Have to use a clip and look at the slit in the side of it then pull that metal clip up and slide the knob off.
Old 04-11-2011, 09:52 AM   #4
Stang.racr's Avatar
Not to jack your thread but I got a similar problem. At night if I turn my interior lights on my dash lights go off until I turn cabin light back off
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-11-2011, 09:53 AM   #5
bbunt302's Avatar
I had strange issues with mine before that caused the turn signals not to work. It turned out to just be a loose wire on the back of the switch. On the foxes it's not as bad to pull the switches out. They just sort of clip into place.
Scary stuff.
Old 04-11-2011, 03:14 PM   #6
Otlaw80's Avatar
Agree with everyone else. Most likely a headlight switch fairly common and simple
Old 04-11-2011, 04:19 PM   #7
gixxer007's Avatar
Very common issue in the fox's for sure they sell them new fairly cheap to replace.
gixxer007 is offline   Reply With Quote
Old 10-17-2014, 04:05 PM   #8
I joined this forum just to say how f@#%ing beautiful your Red fire is. I never really cared for the New Edge body style, but you've definitely changed my mind. I'd enjoy seeing your build list, After seeing it my wife asked me to buy the 2004 Cobra Convertible from her friend, so I did. WTF she's worth it.
Vindicated95 is offline   Reply With Quote
Old 10-18-2014, 11:40 PM   #9
kyle_rivas's Avatar
I had the same problem your switch in the back where the wires are plugged into the switch could be burnt up
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 10-19-2014, 01:39 PM   #10
Chris01's Avatar
Yep the wiring harness on the light switch burns up mainly on the gt models but this can happen to an LX also. But most of the time it's the switch itself Click image for larger version
Name:	ImageUploadedByMustang Evolution1413747576.104065.jpg
Chris01 is offline   Reply With Quote
Headlight switch on dash Murph00 Pre-2005 V6 Mustang 17 05-02-2005 06:23 AM
My headlight switch is broken, help DropTop_Stang Pre-2005 V6 Mustang 6 10-15-2003 04:59 PM
12:28 PM
