Problems with 1991 Mustang GT - Mustang Evolution
Old 08-05-2007, 05:46 PM   #1
My 1991 Mustang GT spudders, and hesitates when I start it up and while Im driving. It will sometimes die on my and I let it sit for 15 mins and it will fire right back up like nothing happened. It doesn't happen everytime through. It can run for weeks and not mess up then the next day it can be acting up. Im not sure what is wrong and the guy that works on my car can't figure it out. I took to Ford and they couldn't find anyting wrong with the car. Can anyone help me?
wmsoccer28 is offline   Reply With Quote
Old 08-05-2007, 06:12 PM   #2
Re: Problems with 1991 Mustang GT
I would check/replace the following
plugs (gaped right)
plug wires
rotor/cap for distributor
fuel filter
also clean your maf and check/clean air filter
Old 08-05-2007, 06:32 PM   #3
Thanks I changed the wires and plugs but not the other stuff.
Old 08-05-2007, 07:36 PM   #4
rocknbronco's Avatar
Clean out the tps as well.
rocknbronco is offline   Reply With Quote
Old 08-05-2007, 08:07 PM   #5
What is the TPS?
Old 08-05-2007, 08:29 PM   #6
wiarumas's Avatar
Originally Posted by wmsoccer28 View Post
What is the TPS?
yeeeaahhh... im gonna have to get you a copy of that memo.
Old 08-06-2007, 03:06 AM   #7
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
What is the TPS?
The tps is the throttle position sensor
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 08-06-2007, 08:53 AM   #8
Zim
You want to **** me?
Zim's Avatar
plugs (gaped right)
plug wires
fuel filter
Id also replace your coil, maybe run some seafoam through the car, and put a mechanical guage on your fuel pressure to make sure your fuel pump isnt weak
I like toys
Old 08-06-2007, 11:05 AM   #9
I had a fuel pressure gauge on it came back good
Old 08-14-2007, 11:15 AM   #10
dragonlouie's Avatar
Sounds to me like your fuel pump is getting too hot for some reason. Have u changed it or is it still the original? If its the original i would change it.:burnout:
DRAGONLOUIE
dragonlouie is offline   Reply With Quote
Old 08-20-2007, 09:48 PM   #11
jbuckshot's Avatar
check your mass air
jbuckshot is offline   Reply With Quote
1991 mustang
1991 Mustang GT captaindrift Mustangs for Sale and Wanted 0 09-05-2006 11:38 AM
Red 1991 GT Mustang Bo408 1979-1995 Mustang GT 7 01-04-2005 11:54 PM
06:08 PM
