plz anybody help me!!!!!!!! - Mustang Evolution
Old 04-13-2011, 11:33 AM   #1
heres the deal in 2yrs i have replace 3 distributors 4 ingnition coils and 4 fuel pumps now fuel pump i just replace the other day with bbk 255 hi volume push it a little hard on freeway car started jerk a little rpms guage went crazy for a second once i slowed down everything was fine till i hook up my obd1 code reader got a code 211 which is profile ignition pick up now heres my ? theres has to be something else going on for me to keep replacing these same parts some one told me that it maybe my ground any ideas on what this could be if it is my ground wires which ones would it be and where are they plz help me i have spent 2500 in these same parts over 2yrs and im tired of it i cant move to the next project which is my exhuast till i get this done right
durtyred69 is offline   Reply With Quote
Old 04-13-2011, 12:17 PM   #2
It could be grounds. Check battery cables and grounds. Also check all of the rest of your grounds. You're gonna have to hunt for them. What distributer are you running?
Alscobra is offline   Reply With Quote
Old 04-13-2011, 12:27 PM   #3
Re: plz anybody help me!!!!!!!!
msd
Old 04-13-2011, 12:28 PM   #4
i dont know where all the grounds are are they pretty visible under the hood and roughly how many do i have
Old 04-13-2011, 12:55 PM   #5
Brett Greene's Avatar
Deff the grounds. I had the same problem took it to a shop. They replaced all the grounds for me. Cost me like 150 bucks
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-13-2011, 01:08 PM   #6
roughly how many grounds r there
Old 04-13-2011, 09:23 PM   #7
Titus Wadicus
svtlx's Avatar
there's lotsa grounds at different point in the car.
pins 20, 40 and 60 in your pcm are grounds. ground them straight to the body from the pcm if you have (under passenger side kick panel).
make sure u have a ground wire from the engine to the body.
check ground from battery to body and make sure it's tight.
hopefully this will get u in the right direction.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-13-2011, 11:37 PM   #8
+1 and you can always add grounds like I did. I had 4 grounds from the motor to the body, not any little wire grounds, I used the same size as the battery cables.
Straublittleman is offline   Reply With Quote
Old 04-14-2011, 11:06 AM   #9
I'm trying that now add a ground ill let you know how it goes
Old 04-14-2011, 04:37 PM   #10
thanks i added a ground hope it fixes the problem it did fixes my cluster guages temp battery and oil pressure been dealin wit that for yrs thanks bro
Plz need help Mustang240 General Mustang Discussion 9 03-03-2011 05:24 PM
need some help plz. j4gwig General Mustang Discussion 2 05-10-2010 05:29 PM
plz welcome me Qatari Mustang New Member Introductions & Greetings 10 09-24-2009 09:20 AM
I need help!!! PLZ!! Khstang Pre-2005 V6 Mustang 18 04-21-2008 10:33 PM
Need some help plz! graveelement Pre-2005 V6 Mustang 0 02-09-2008 03:15 PM
08:23 PM
