New exhaust - Mustang Evolution
Old 04-14-2011, 01:54 PM   #1
stangstar92's Avatar
New exhaust
We just put on a new pypes off road mid pipe and there one problem I have...theres a 3/4 inch piping that used to bolt up to the stock midpipe on the hanger in the middle. it leads to somewhere towards the motor...can anyone tell me what that is???
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 04-14-2011, 02:16 PM   #2
93slowstang's Avatar
It goes to the smog pump.
Old 04-14-2011, 02:26 PM   #3
What does it do, can it be removed?
Old 04-14-2011, 02:42 PM   #4
Brett Greene's Avatar
Smoke delete kit. Gain like 10 horse and lose some weight while your at it
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-14-2011, 04:00 PM   #5
gixxer007's Avatar
Re: New exhaust
I just took mine off you can buy a smog delete pulley for about 75.00 or so that will fill the spot the smog pump comes off. The only issue you may have is if you are in a state the checks for them for any reason.
gixxer007 is offline   Reply With Quote
Old 04-14-2011, 04:16 PM   #6
Stang.racr's Avatar
DONT BUY SMOG delete pulley and bracket. All u do is go buy a shorter belt and don't run it over the smog pump. That bracket is a waist of money. I did it on all my foxes and threw pump away
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-14-2011, 04:21 PM   #7
Plus 1. That's what I did. I totally forgot about that
Old 04-14-2011, 04:57 PM   #8
gixxer007's Avatar
Re: New exhaust
I just do it this way so I can get a replacement belt easy I guess. Plus I kind of liked the look of the billett pump delete I got.
Either way works fine I guess.
Old 04-14-2011, 05:32 PM   #9
Stang.racr's Avatar
Re: New exhaust
yeah u do got a point there, i have no idea what size my belt is
Old 04-14-2011, 05:56 PM   #10
Titus Wadicus
svtlx's Avatar
Re: New exhaust
both yall make sum good points there. that's wut i did too (short belt). but i stuffed the belt jackets in my tool box so i know the size.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-14-2011, 07:34 PM   #11
bbunt302's Avatar
Somewhere in the vast expanse of the internet I've seen a diagram with all the correct 5.0 belt sizes and routes for different pulley configurations. It's been years though.
Found it: http://i238.photobucket.com/albums/f...his71/doit.jpg
Scary stuff.
Old 04-14-2011, 08:27 PM   #12
Stang.racr's Avatar
That's awesome man. Some good info
Old 04-14-2011, 08:30 PM   #13
Stang.racr's Avatar
I'm sure that is with stock pulleys though right
Old 04-14-2011, 10:06 PM   #14
bbunt302's Avatar
I believe so. I think with no smog pump and underdrives I ran about an 82" belt instead of the 84.5".
Scary stuff.
exhaust
v6 exhaust El Jefe Pre-2005 V6 Mustang 35 01-08-2010 02:11 AM
New Exhaust coolstang Pre-2005 V6 Mustang 8 01-15-2005 08:15 PM
Exhaust 00StangV6 Pre-2005 V6 Mustang 22 01-06-2005 02:36 AM
Exhaust coolstang Pre-2005 V6 Mustang 14 12-13-2004 05:25 PM
12:59 PM
