302 tick - Mustang Evolution
Old 04-15-2011, 10:41 PM   #1
302 tick
I have a 302 4bbl in my 79 mustang, I just replaced the camshaft and now I have a tick that increases with rpm that wasnt there before. When I installed the cam I torqued the rocker bolts with valves closed. I did use different pushrods is it possible that oil isnt passing through them and us causing a tick? Thanks for you help guys. Kevin.
Dexter is offline   Reply With Quote
Old 04-15-2011, 10:56 PM   #2
Did you check if your header bolts are tight? I had the same sound and it was loose header bolts! Hope it ain't a bottom end problem
BackhalvedLX is offline   Reply With Quote
Old 04-16-2011, 02:09 AM   #3
Re: 302 tick
Probably not a bottom end problem. Did you reuse the lifters? Probably just a sticky lifter.
93CobraGuy is offline   Reply With Quote
Old 04-16-2011, 06:49 AM   #4
stampde's Avatar
Re: 302 tick
I'd go back and re torque the rockers , and also check for a header leak like backhalved said ..... also run it a little bit could be a sticky lifter ??
2011 GT Auto
Old 04-16-2011, 10:01 AM   #5
wereKEV's Avatar
Re: 302 tick
If you run it for a while ,if it is a lifter it might loosen itself up .
wereKEV is offline   Reply With Quote
Old 04-16-2011, 11:17 AM   #6
Titus Wadicus
svtlx's Avatar
Re: 302 tick
sounds like a bad lifter if it isnt an exhaust leak.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-16-2011, 11:21 AM   #7
wereKEV's Avatar
Re: 302 tick
If it's clicking it could also be a bad plug wire arcing also.
Old 04-16-2011, 07:16 PM   #8
Wow listen to this, I took the intake and valve covers off to discover that I had bent 6 pushrods!! The weird thing is that they went bent when they went in. I guess I'm gonna have to get some stronger rods. Thanks for all the replys guys I like posting here.
Old 04-16-2011, 07:57 PM   #9
Titus Wadicus
svtlx's Avatar
Re: 302 tick
how big is the cam? did u clay the pistons before u put it together all the way? i wonder if your valves are hitting the pistons causing the the pushrods to bend. just a thought sense u said u did a cam swap.
Old 04-17-2011, 09:17 AM   #10
wereKEV's Avatar
Re: 302 tick
that's true iy must be a piston hitting something to bend a push rod .
Old 04-17-2011, 09:42 AM   #11
bbunt302's Avatar
You also need to measure to ensure you have the correct length pushrods.
Scary stuff.
Old 04-17-2011, 10:21 AM   #12
wereKEV's Avatar
Re: 302 tick
Thats for sure otherwise you will be pulling it apart again to fix the f ups.
302 Blackpony Classic Mustangs 6 12-21-2010 09:05 PM
i have a 66 302 need help guitarsav276 Classic Mustangs 5 03-30-2010 07:52 AM
Got the 302 SC_STEEDA Classic Mustangs 1 03-09-2010 06:59 PM
68 302 V8.. Fishers Stang Classic Mustangs 13 04-27-2006 05:57 PM
tick in new motor? hoof Pre-2005 V6 Mustang 6 04-27-2005 06:09 AM
06:00 AM
