Upper Manifold For 86? - Mustang Evolution
Old 04-19-2011, 12:16 PM   #1
Hey guys I was wondering if a gt-40 upper intake will fit in my 86 mustang and if so will I have to convert it to Maf?
Dgasca101 is offline   Reply With Quote
Old 04-19-2011, 01:24 PM   #2
stampde's Avatar
Re: Upper Manifold For 86?
you have to switch the lower also , it will not bolt up the stock lower so you need the whole intake ,,,,,,,
2011 GT Auto
Old 04-20-2011, 07:49 AM   #3
Titus Wadicus
svtlx's Avatar
^^^what stampde said^^^....and no, you dont have to convert to maf
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Upper intake manifold Blackedout Pre-2005 V6 Mustang 2 04-13-2011 01:18 PM
Intake manifold ridenmystang 1996-2004 Mustang GT 9 04-23-2007 09:45 PM
Exhaust manifold megax29 Pre-2005 V6 Mustang 31 05-20-2006 01:25 PM
Got my Stage 4 Upper in Brent Pictures and Videos 17 02-15-2005 09:18 PM
cracked pi manifold greg_g70 1996-2004 Mustang GT 8 12-10-2004 11:55 AM
03:57 AM
