302 adjustable rocker? - Mustang Evolution
Old 04-19-2011, 08:54 PM   #1
I've been having some problems with pushrods length with my new cam, a friend of mine has some heads with bolt in rocker (like the 351w heads) instead of stud mount, are these adjustable rockers?
Dexter is offline   Reply With Quote
Old 04-20-2011, 07:38 AM   #2
Titus Wadicus
svtlx's Avatar
Re: 302 adjustable rocker?
so your talkin bout pedestal mount right? pedestals aren't exactly adjustable.. you can shim them a few thousandths though. even if you use pedestal mount, you may still have to get custom length pushrods. i have pedestal mount 1.7rr and i have to run +.117" length pushrods over stock.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-20-2011, 12:41 PM   #3
stampde's Avatar
not adjustable !!! 17 lb ft of torque
you should get a push rod length checker from comp cams 7702-1 about $15
2011 GT Auto
Old 04-20-2011, 07:47 PM   #4
Thanks for the advice guys now I have somewhere to start to make things right again.
Old 04-20-2011, 08:03 PM   #5
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Are they aftermarket or stock?
-Will
Knight F Mohawk is offline   Reply With Quote
Adjustable quadrant cable bizwaks 1979-1995 Mustang GT 3 01-22-2011 08:44 AM
Adjustable crane cam rocker arm problems ballajb 1979-1995 Mustang GT 8 11-04-2009 09:30 AM
adjustable clutch cable jt2000gt 1996-2004 Mustang GT 5 12-28-2007 07:43 PM
adjustable springs mitch Pre-2005 V6 Mustang 0 06-09-2007 03:06 PM
Adjustable FPR's Zim 1979-1995 Mustang GT 6 05-06-2006 05:48 PM
04:33 PM
