Gt-40 intake Manifold Mods - Mustang Evolution
Old 04-21-2011, 07:06 PM   #1
Quick question are there any specific modifications I have to do before installing the Gt-40 intake manifold?
Dgasca101 is offline   Reply With Quote
Old 04-21-2011, 07:29 PM   #2
Brett Greene's Avatar
Wouldn't even waste your time on putting it on
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-21-2011, 08:31 PM   #3
bbunt302's Avatar
Why not? The GT-40 intake flows pretty well.
Scary stuff.
Old 04-22-2011, 06:42 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Gt-40 intake Manifold Mods
i agree, itsa good starting point.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-22-2011, 06:45 AM   #5
Save the money and buy a full top end kit. Go all trick flow or sumthing
Old 04-22-2011, 06:54 AM   #6
bbunt302's Avatar
I'd personally rather have the GT-40 intake than the Trick Flow for a non stroked N/A 302. The GT-40 is well proven to make more torque than the base Trick Flow, Edelbrock and Cobra intakes. It just normally comes with a higher price tag as well.
As far as the OP, the only thing I can think you'll need are gaskets.
Scary stuff.
Old 04-22-2011, 07:12 AM   #7
Titus Wadicus
svtlx's Avatar
+1 ...
Old 04-22-2011, 10:30 AM   #8
stampde's Avatar
I have had good luck with that intake in the past also !!!
+2
2011 GT Auto
Old 04-22-2011, 02:28 PM   #9
gixxer007's Avatar
I would have to agree it is a good starting point for sure. It will only keep growing from their trust me once you start it is not easy to stop buying and adding stuff.
Good Luck
gixxer007 is offline   Reply With Quote
Old 04-22-2011, 03:53 PM   #10
Good mod IMO also. Go with a set of GT40 iron heads with it and pull out a bit more power. You won't be disappointed with the gains there.
93CobraGuy is offline   Reply With Quote
Old 04-22-2011, 10:55 PM   #11
Thanks alot guys now I won't have to do any modifications right I can install manifold without any problems all I have are bbk headers engine wise now what size throttle body should I get ?
Old 04-23-2011, 04:46 AM   #12
I would do a 65mm or a 70mm.
Old 04-23-2011, 06:25 AM   #13
Stang.racr's Avatar
I'm running gt40 intake with 98 ford explorer gt40p heads with 65mm tb and it works good. I think gt40 intake flows as cobra and way cheaper
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-23-2011, 10:09 AM   #14
stampde's Avatar
flow's the same . intake's are the same ,except the Cobra upper is cast while the GT40 has separate runners , witch tends it to run slightly cooler than the Cobra ...... explorer heads are great budget heads !!!!
had an 88 t-bird Turbo coupe that i put a 5.0 in once ,with an e303 cam gt40p (explorer heads ) and an edelbrock perf rpm int and 650 carb , it ran 12.50's all day , Dpn't think i had more than $2,000 in the whole car ?
2011 GT Auto
Old 04-23-2011, 08:12 PM   #15
Stang.racr's Avatar
That sounded like a great budget car there bud
New Intake Manifold! Chick Nasty 1996-2004 Mustang GT 21 08-12-2010 03:15 PM
intake manifold? blackonblack Pre-2005 V6 Mustang 10 01-07-2010 07:49 PM
intake manifold Senorjizzy Pre-2005 V6 Mustang 1 08-30-2009 01:20 AM
Intake Manifold 2 99'sleeper Pre-2005 V6 Mustang 4 03-07-2005 06:29 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
12:33 PM
