New member and needs help - Mustang Evolution
Old 04-24-2011, 02:51 PM   #1
93stangster's Avatar
Hi everyone.... I'm new member lookin for some help... I'm Tryin to build a show and strip car... Its a 93 gt I'm puttin a 347 in it and I'm lookin for some good heads and cam to go with my typhoon upper and lower.... Or is that a good intake... Thanx and need some help and wanna learn
93stangster is offline   Reply With Quote
Old 04-24-2011, 03:01 PM   #2
You can't go wrong with the trick flow set up. Heads and cam. The gt40 intake really shows well also and performs.
Alscobra is offline   Reply With Quote
Old 04-24-2011, 03:12 PM   #3
Re: New member and needs help
So are u sayin i should get rid of the typhoon intake.... It's just I'm a big chrome or polished guy and it is..
Old 04-24-2011, 03:20 PM   #4
I don't know the typhoon. If you like the look of it then keep it. Trick flow cam and heads are recommended for sure though.
Old 04-24-2011, 03:46 PM   #5
Titus Wadicus
svtlx's Avatar
the typhoon is the same as the edlebrock efi intake...they're interchangable top and bottoms
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-24-2011, 03:59 PM   #6
So where would u recommend findin those heads and intake for a decent price... And svtlx do u think my intake is alright
Old 04-24-2011, 06:32 PM   #7
Titus Wadicus
svtlx's Avatar
i think a trickflow intake would be better for a 347 with decent heads. but you can still make good power with the typhoon, i used to own one. as far as your heads and cam you could check out jeg's or even ebay... i buy lotsa go fast stuff off of ebay! also, as far throttle body, i would suggest 70ml if your goin with the 347 or boost regardless of intake choice.
Old 04-25-2011, 06:26 AM   #8
bbunt302's Avatar
I would recommend AFR 185 heads if you can afford them. If not, the Trick Flow will suffice.
As far as the intake, the Typhoon will work as long as it is a Performer RPM rip off and not just the base Performer.
Scary stuff.
Old 04-25-2011, 06:12 PM   #9
How could I tell the difference...
Old 04-25-2011, 06:52 PM   #10
gixxer007's Avatar
I have AFR heads and love them they really perform great and are worth every penny IMO.
gixxer007 is offline   Reply With Quote
Old 04-25-2011, 07:44 PM   #11
Titus Wadicus
svtlx's Avatar
idk.. i thought there was only one version for efi.
Old 04-25-2011, 07:49 PM   #12
bbunt302's Avatar
Edelbrock actually has 3 EFI 5.0 intakes:
Performer
Performer RPM
Performer RPM II
After some more reading, apparently all the Typhoon intakes are rip-offs of the original Performer RPM.
Scary stuff.
Old 04-25-2011, 07:57 PM   #13
Titus Wadicus
svtlx's Avatar
Performer
Performer RPM
Performer RPM II
a damn good rip-off too might i add...100%interchangable with the original... and they come in polished too. let's not forget, waaay cheaper than the edelbrock version as well. i loved my typhoon. 5.0 magazine tested it, it's better than motorsport stuff through most of the rpm range.
Old 04-25-2011, 08:17 PM   #14
Brett Greene's Avatar
I have AFR 185s with a port n polish along with polished trickflow intakes and a custom made cam buy trickflow as well. My 347 made 405 rwhp NA. Very good set up I recommend 100 percent
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-27-2011, 05:15 PM   #15
What kind of suspension would y'all recommend....
Old 04-28-2011, 01:09 AM   #16
Which Trick Flow heads are being referred to here? They sell several models, each with an option for cnc or not. I will personally vouch for the twisted wedge heads, I think they are a great design. Trick flow cnc heads flow the best of any head with comparable cc runners. AFR is a close runner up, can't go wrong with either brand.
Suspension is going to depend on what you're going to use the car for. Do you want it to corner well or come out of the hole well? Do you care about ride comfort? How much money do you want to spend on it?
85GTPony is offline   Reply With Quote
Old 04-28-2011, 02:57 AM   #17
I want a good hole shot is what I'm Tryin for.... And it's goin to be a daily driver so comfort would be nice..... Cash flow on the decent side but a lil low funded.... Savin Tryin to build this car right....
Old 04-28-2011, 09:31 AM   #18
Titus Wadicus
svtlx's Avatar
comfort and good hole shot are'nt really combinable for the same sentence in my experience.
sum upper and lower trailing/control arms and perhaps sum spherical axel bushings would prolly help u out a bit (ok, significantly). however, your trading flexible parts for non flexible parts which will drasticly stiffen the rear suspension... also, u could frame tie the car (sub frame connecters). this will stiffen the chassis and allow the suspension to work better.. key word there is stiffen. all these mods make the car alot stiffer and definatley take away from comfort or softness of the ride.
you could buy all those pieces for around 500 or less.
and another trick that works is using a torque brace. jeg's sells them for 60-70 bucks, but i bought mine from lowe's for 8 bucks.
Old 05-10-2011, 07:38 PM   #19
I use a gt40 on mine
1995mustang is offline   Reply With Quote
Old 05-13-2011, 08:09 PM   #20
WhiteCobra94's Avatar
Stick with the typhoon, that's the intake I'm gonna be running with the Edelbrock performer RPM heads and TFS stage 1 cam, I'm still in the build process and if you have this months 5.0 Magazine there's a 91 lx fox body, which is running a typhoon intake with a T70 turbo !
New member from NJ Scrshaw New Member Introductions & Greetings 8 11-30-2010 08:08 PM
New member from VA Stealth05 New Member Introductions & Greetings 11 12-15-2009 05:31 PM
new member 96 cobra2tone New Member Introductions & Greetings 10 12-02-2009 09:42 PM
K-Member snake428CJ Pre-2005 V6 Mustang 1 03-17-2007 07:35 PM
new member demetlaw New Member Introductions & Greetings 15 02-19-2007 10:15 PM
06:22 AM
