E7 heads - Mustang Evolution
Old 04-24-2011, 10:10 PM   #1
E7 heads
I jst bought a set of e7 heads. Im not very fimilare with them. Anyone know how they perform?
hann93lx is offline   Reply With Quote
Old 04-24-2011, 10:28 PM   #2
roger306's Avatar
Region: New Mexico
They work ok just need to port them out and have the guides cut down for higher lift cams. I would install the GT 40 springs with chrome Molly retainers and have the seat cut out for 194 intake & 160 exh valves that's what I did on my 306 and they worked out very well but all side I am going to AFR 185 the next cam change I do
roger306 is offline   Reply With Quote
Old 04-24-2011, 11:52 PM   #3
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: E7 heads
All things considered, they're "ok"....better than most other stock 302 heads, but NOTHING near what an aftermarket head can do.
What are your goals? Why did you purchase them? For what car?
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-25-2011, 05:27 AM   #4
Re: E7 heads
I jst want a pretty fast street car. I have a 93 lx with msd igniton cold air bbk shorty headers bbk h-pipe and flows. I bought the heads off a friend of mine. I bought the e7 heads and an anderson n41 cam for $175.
Old 04-25-2011, 07:34 AM   #5
Titus Wadicus
svtlx's Avatar
Re: E7 heads
im totaly lost... was your stang motor disassembled when you bought it? your buying heads that came factory on that car.
im surprised that roger306 spent that much on e7's. i run e7's but i ported them myself so there's no real expense there besides my time and the upgrade springs.
however, i think you got a deal on wut u bought, and should be happy with it if your installing a gear also.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-25-2011, 09:24 AM   #6
stampde's Avatar
Re: E7 heads
their not worth doing all that work to? you can buy a set of after market heads that will totally out perform them for about the same price as all that work ....
2011 GT Auto
Old 04-25-2011, 09:31 AM   #7
Titus Wadicus
svtlx's Avatar
Re: E7 heads
+1
Old 04-26-2011, 06:31 AM   #8
Stang.racr's Avatar
Better than other mustang heads? I'm confused. The e7s is what comes on stock. They alright ported but I would save money to aftermarket or even gt40 heads for few hundred bucks
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-26-2011, 08:00 PM   #9
Titus Wadicus
svtlx's Avatar
Re: E7 heads
yep...
Old 04-26-2011, 08:21 PM   #10
Re: E7 heads
So your telling me this kid sold me aset of heads that i already have on my motor??
Old 04-26-2011, 08:24 PM   #11
Damn. Research saves lives.
Alscobra is offline   Reply With Quote
Old 04-26-2011, 08:29 PM   #12
Titus Wadicus
svtlx's Avatar
Re: E7 heads
i hate to be the bearer of bad news, but yea. unless u got something else on your car. 87-95 had e7te..... 86 had e6 turbo swirl "heart shaped cumbustion chambers"(only made for one year)... im not sure on 85 and under
Old 04-26-2011, 09:05 PM   #13
roger306's Avatar
Region: New Mexico
Oh for the record I did all the work on my heads myself so it was cheap only cost me 250 bucks in parts
Old 04-26-2011, 09:41 PM   #14
Re: E7 heads
Yupp. They also came on most of the truck 5.0 motors. If you want to port them go for it...but they're only worth 50 bucks or so assembled in good shape.
Old 04-26-2011, 10:47 PM   #15
Titus Wadicus
svtlx's Avatar
Re: E7 heads
well u didnt make out too bad then for the 194/160's
Heads Hunter Pre-2005 V6 Mustang 0 04-12-2011 10:32 PM
how can i tell if i have PI heads or not? redbird2289 1996-2004 Mustang GT 4 08-26-2009 08:56 PM
Heads upton7 Mustang Parts for Sale and Wanted 0 08-11-2009 10:51 PM
Which heads? upton7 1996-2004 Mustang GT 4 07-30-2009 11:14 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
09:46 AM
