My official 5.0 engine swap thread - Mustang Evolution
Old 04-26-2011, 11:41 AM   #1
I am starting this thread as the official write up of my 5.0 swap. I plan to update it as best I can as I go along. I just placed an order for about 95% of the parts I have remaining to get....so it is getting to be time to get the party started.
Here's the outline of the project:
Source: 1993 4 cyl Automatic Hatchback
Stage 1 Target: Relatively stock 5.0 swap with T5 manual trans swap as well.
Stage 2 Target: Nice sounding cammed, moderate HP N/A 5.0.
Day by day gallery of work --> Album: Restoration
Parts List to date:
Buddy Freebie Parts (Thanks Gabe. )
  • Electric Fan
  • Modified Stock Midpipe
  • Double Hump trans crossmember
Craigslist and Ebay Parts
MRT-Direct
  • Hood Struts - 80C000-BLK
MGW
  • T5/T45 Shifter
  • Black w/ Yellow Stripes rally ball shift knob
Ordered from Late Model Restoration
  • Ignition Coil - DG470
  • Manual Steering Rack - FR-1890
  • Dizzy Boot Cover - LRS-12252-50
  • Ignition Coil Bracket - LRS-12257A
  • A9L Computer - LRS-12650A
  • O/R Accessory Drive - LRS-3511K
  • Motor Mount - LRS-6038PR
  • Radiator Hose Kits - LRS-6052A
  • Tranny Mount - LRS-6068AU
  • Shift Boot - LRS-7277E
  • Quadrant - LRS-7553C
  • Clutch Cable - LRS-7553DR
  • Firewall Adjuster - LRS-7553H
  • Master Clutch Kit - LRS-7560A-K
  • TFI Module - LRS-F504
  • Dizzy Cap and Rotor Kit - M12106B302
  • Yellow Plug Wires - M12259Y301
  • Valve Covers - M6000F302
  • Valve Cover Bolts - M6680A
  • GT40 Upper to Lower intake gasket - M9486A50
  • Mac Dump Exhaust - MAC-PD2693
  • Chrome Intake Bolt Kit - MG-5006
  • Control Arm Bushings - PT-6209BL
  • Negative Battery Cable - WC8699
  • Positive Battery Cable - WC8751A
Here are a couple pictures of how the car is today.
Full Album: Mustang Evolution - PureVenom's Album: 93 LX Hatch
Old 04-26-2011, 01:15 PM   #2
Las0mbra's Avatar
Sounds like a fun project! Can't wait to see the progress!
Old 04-26-2011, 01:19 PM   #3
stampde's Avatar
Re: My official 5.0 swap thread
I've dont that swap a number of times back in the day , buy a cheap 4cyl 'Stang install 5.0 ,pretty straight forward and Fun !!!! good luck with your project , keep us posted !
2011 GT Auto
Old 04-26-2011, 03:39 PM   #4
Great project! Wish you the best on the build!
93CobraGuy is offline   Reply With Quote
Old 04-26-2011, 04:05 PM   #5
Can't wait to see how it goes! I can't wait to get mine when I get it and may be referring back to this thread...
Old 04-26-2011, 05:07 PM   #6
MC770's Avatar
Going to be fun when its done!
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 04-26-2011, 05:24 PM   #7
Awesome! Subscribed to thread
Old 04-26-2011, 07:55 PM   #8
gixxer007's Avatar
Good luck and have fun.
gixxer007 is offline   Reply With Quote
Old 04-26-2011, 09:25 PM   #9
Titus Wadicus
svtlx's Avatar
im work'n on my swap as we speak 96v6 to 5.0 efi. i gotta get a cam. perhaps i can start a competing thread...lol.
btw, your gonna need a throttle cable and (cruise cable optional)..... also you're gonna have to fab up sum fuel line extensions cause the fuel lines are on the opposite side and a bit short. just thought i would add that cause i didnt see it on your list.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-27-2011, 01:06 AM   #10
Hmm, forgot to put the fuel cable on the eBay list. Fuel lines may get bought new, or if I can find the write up again on how to flip the stockers to the other side I will try that first.
Old 04-27-2011, 09:18 AM   #11
Titus Wadicus
svtlx's Avatar
just unbolt the lines from the hangers underneath, and slowly bend them over to the left side of the car. however, u will still be bout 15-24" short (from fender to fuel rail). u should be able to find sum short lenghts at the junk yard to compensate.
u can get the throttle cable and pcm from lincoln mark 7 if u cant find any v8 stangs at a junk yard, and prolly the fuel line as well.
2000-up taurus have 24lbs injectors also if u need sum cheap ones.
Old 04-27-2011, 09:22 AM   #12
Titus Wadicus
svtlx's Avatar
o yea, u can get a fan shroud and overflow tank from the lincoln as well. and i didnt see a rear sway bar on your list.
also, pretty sure u can use the tranny mount off the existing trans.
Old 04-27-2011, 09:32 AM   #13
Site Sponsor
Sponsor
Jarrod@latemodel's Avatar
Looks good man. Cant wait to see the final product.
Jarrod@latemodel is offline   Reply With Quote
Old 04-27-2011, 10:10 AM   #14
The motor came complete with injectors and all that. This is how the motor sits right now:
I just need to get this damn bracket off the cobra so I can swap out my lower pulley and start driving it again so I can pull the motor in the fox. 2 Allen bolts completely rounded out...Ugh.
Old 04-27-2011, 11:27 AM   #15
Titus Wadicus
svtlx's Avatar
ahh sweet, that's all kinds of awsome... im jelous. let me shut da fuk up then..lol looks u got it handled.
Old 06-26-2011, 01:25 PM   #16
And so it begins. Pulled
Out the interior today. Floors are shockingly clean. I expected some Rust issues for sure.
Dome for the day due to feeling super nauseous.
ID:	28386   Click image for larger version
Old 06-26-2011, 07:01 PM   #17
Ok, gave the carpet a quick wash. Didn't do too thorough of a job as it needs replacing down the road due to sun bleaching.
Here's a before and after. I'll get a better after when it's dry. It's hanging up at the moment.
The after is the passenger side.
ID:	28419   Click image for larger version
Old 06-26-2011, 08:30 PM   #18
junoS197Bl08's Avatar
awesome project, looks like ur doing good so far, keep us posted.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-26-2011, 08:31 PM   #19
Awesome! Can't wait to see the progress.
Old 10-03-2011, 03:50 PM   #20
NeedSomeMods's Avatar
This sounds like it's going to be awesome when it's finished. Any progress? Your car will probably be a LOT cleaner than mine when it's completed.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 10-03-2011, 04:58 PM   #21
None...getting married next weekend...so, the project has been on a temporary hiatus until the wedding is paid for and we get back from the honeymoon (vegas). Then, it'll be time to get some work done. I have a majority of the parts ready...just need to time and non-100* weather to get it done....november should be a productive month.
Old 12-06-2011, 07:10 PM   #22
lateralzero's Avatar
Region: Iowa
Parts List to date:
  • Electric Fan
MRT-Direct
MGW
  • T5/T45 Shifter
Be sure to change over the rear brake lines the exhuast on a V8 can melt the rubber hoses on the 4 banger style due to their location.
lateralzero is offline   Reply With Quote
Old 12-30-2011, 07:56 PM   #23
Well, the process to pull the motor has officially begun. I don't have any pictures right now as I ran out of light, but, I'll update with them tomorrow when I snap some. Hoping to have everything disconnected this weekend and the motor ready to pull once I rent a picker.
Today was:
Removed radiator
Removed Battery and Tray
Disconnected the engine harness (all but one plug I couldn't see where it went due to low light)
Next up is to disconnect everything from the trans, pull the trans, disconnect the rest of the cooling system hoses, and unhook the AC. Probably won't be able to touch it tomorrow due to going out of town for new years...but hopefully sunday if I'm not too hung over.
Old 12-30-2011, 09:15 PM   #24
TaylorF25's Avatar
I just subscribed but I was thinking about slowly starting to do one of these projects myself. Is there anywhere that I can go (online) to pull up like a guide or something? I know car basics but I'm trying to learn as much as possible and a project like this seems like a great way to learn everything. This would be my first major car project, any thoughts/help would be greatly appriciated. Not trying to jack your tread man lol
TaylorF25 is offline   Reply With Quote
Old 12-30-2011, 09:34 PM   #25
There are several swap guides out there. I forgot which sites I read them on now, but if you search for 5.0 swap you'll see a number of them. We need something like that on here as well. I'm going to try and document the process as best I can and with which parts I had to update and what not.
Old 12-30-2011, 10:32 PM   #26
TaylorF25's Avatar
That would be great because I will deff refer back to it. If you could maybe sent it to me that would be awesome, if not ill try to use it on here. As detailed as you can write down would be the best. Thanks man!
Old 12-31-2011, 01:42 PM   #27
Managed to get a couple hours of work in this morning. Pulled out the AC, power steering, remaining vacuum and cooling lines, and pulled out the main wiring harness. Happy new year everyone.
Also, updated the first post with a link to the full album of progress. It will have all the pics I post here and maybe extras as I probably won't post all of the pics here.
Here are the pics of yesterday and today's progress.
ID:	36962   Click image for larger version
ID:	36964   Click image for larger version
ID:	36966   Click image for larger version
ID:	36968   Click image for larger version
ID:	36971   Click image for larger version
Old 12-31-2011, 04:36 PM   #28
Progress!
I wish we were closer. I was eyeballin' that 2.3 you're pulling and my Ford utility tractor.
I believe with the engine, harness and computer I could make it work.
Old 12-31-2011, 07:11 PM   #29
Originally Posted by Trojan Horse
Progress!
Let me know, ill save it for you if yo decide a road trip for Mardi gras sounds good.
Old 01-01-2012, 05:43 AM   #30
Thank You! I've been wanting to do a road trip.
The wife loves to travel, so if I get healed up enough to where I can travel again before too much longer, we might just do that.
Old 05-15-2012, 03:10 PM   #31
Well? What's happening?
2000 V6 - RIP
The '94 -
Old 05-15-2012, 07:49 PM   #32
+1
Old 07-10-2012, 11:25 PM   #33
Krazy Horse's Avatar
not to steal your thread but i swapped a 4 for a nasty 347 stroker with e303 cam n 30# injectors.had to change body harness to, may have been because my body is a 88 vert. but i have swapped a 32 valve 96 cobra motor into a 92 hatch but it does not run yet, need to figure out why not getting coil pack signal
Krazy Horse is offline   Reply With Quote
Old 07-18-2012, 09:02 PM   #34
Hit a patch of quick sand known as life. Motor is about ready to go in...a bunch of small hiccups have changed my plans with the car. Now the goal is just to get the motor in and running so I can stop driving the cobra daily.
Old 07-20-2012, 10:00 PM   #35
Good plan! The fox will be easier/cheaper to maintain for DD duty. Glad you got the ball (sorta) rollin on this project.
2000 V6 - RIP
The '94 -
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 02:31 PM
4 Cylinder to a 5.0 engine swap? Blackcat 1979-1995 Mustang GT 1 09-18-2012 06:26 PM
Engine and tranny swap Mustanglife General Mustang Discussion 1 07-10-2011 12:32 PM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 09:07 PM
Strange engine swap idea ArmyStang 1996-2004 Mustang GT 25 07-05-2011 11:29 AM
05:53 AM
