410s and what converter? - Mustang Evolution
Old 04-27-2011, 09:07 AM   #1
08v6's Avatar
Just like the title says, I've got 410s on an 88 with an aod, what's the best tourque converter to run times, and still feel like a stock converter on the street?
Faster Than A Speeding Ticket! Black 88 Five0, Pull Me Over Red 08v6
08v6 is offline   Reply With Quote
Old 04-27-2011, 09:33 AM   #2
Titus Wadicus
svtlx's Avatar
Re: 410s and what converter?
i dont know of any stall converter that feels like a stock converter during street driving. the higher the stall... the higher/more, the slip....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-28-2011, 02:17 AM   #3
I don't have any experience with autos in 5.0's but have a C4 in a ranchero with a 2200 stall speed and love it. Converter is a TCI brand
85GTPony is offline   Reply With Quote
Old 04-28-2011, 10:15 AM   #4
Titus Wadicus
svtlx's Avatar
then i would say do a 2200 in your stang as well. the higher the stall the less stock the tranny will feel.
Old 04-28-2011, 12:09 PM   #5
08v6's Avatar
Yeh I saw b&m has a 1900 stall I figure that will be fine I just don't want to be launching at every light unless I want to
Old 04-28-2011, 12:22 PM   #6
Keep in mind also that having a 1900 or 2200 stall does not mean that you will rev that high before you start moving. It just means it will rev a little higher because it is slipping more. The rating is an approximation of when the converter is fully grabbing, but there are even other variables for that.
Old 04-28-2011, 01:02 PM   #7
Titus Wadicus
svtlx's Avatar
yea, i have a 24-2500 stall. and it doesnt flash till 2800
Old 04-28-2011, 01:05 PM   #8
Titus Wadicus
svtlx's Avatar
it doesnt work that way, u have to be w.o.t. for u to launch it. the trans will just feel like it's slightly slipping at lower rpm (2000-2500) during normal street driving.
Old 04-28-2011, 10:42 PM   #9
Blustreek's Avatar
Region: Hawaii
Check into ur camshafts operating range (power band) then you'll know what TC stall to go with.
Blustreek is offline   Reply With Quote
What Torque Converter? WhiteCobra94 1979-1995 Mustang GT 6 03-29-2011 08:27 PM
Torque Converter joeysull Classic Mustangs 4 06-08-2010 06:33 PM
torque converter b's stang 2005-2010 Mustang GT 1 03-04-2010 03:43 PM
Torque converter DarkShadow Pre-2005 V6 Mustang 5 05-07-2006 08:36 AM
torque converter tealstangman 1996-2004 Mustang GT 4 04-06-2006 06:51 PM
08:11 PM
