speedo help - Mustang Evolution
Old 04-27-2011, 08:44 PM   #1
speedo help
so whoever i bought my 88 gt from did a coversion from auto to manual transmission.they never hooked up the spedometer cable and i cant seem to find out where to plug it in.are auto and manual different?please help with any good advice.
Old 04-27-2011, 09:19 PM   #2
93slowstang's Avatar
The hookup for it on the tranny is in the middle driver side of the tail housing.
Old 04-27-2011, 09:21 PM   #3
And the speedo gear that attaches to the sensor at the transmission is different between auto and manual.
Old 04-28-2011, 03:49 AM   #4
gixxer007's Avatar
Re: speedo help
They may have put some type of plug in the spot where it goes. I have seen people do that and make a simple plug to be sure not to loose fluid.
gixxer007 is offline   Reply With Quote
Old 04-28-2011, 06:02 AM   #5
I'll check it out.thanx guys.
Old 04-28-2011, 07:10 AM   #6
CrimsonGT's Avatar
Am I the only one thinking this is the only place where the words speedo tranny and tail can be mentioned in the same post and it not be dirty
CrimsonGT is offline   Reply With Quote
Old 04-28-2011, 08:05 AM   #7
I believe your right but don't forget about "plug".
Old 04-28-2011, 12:17 PM   #8
Titus Wadicus
svtlx's Avatar
Re: speedo help
whoever did the swap was fukn lazy. ive taken the speedo gear outa my t5 and popped it right into my aod. not to mention, even if u go from electric to cable driven, the speedo gears are still swapable.
sound like the guy was too lazy to pull on the speedo cable... cause there is a difference in lengths between t5 and aod, but if u pull the right way the cable will still go on.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-28-2011, 02:25 PM   #9
he was def lazy.i have spent hours upon hours trying to unrig everything.the speedo cable is mechanical.
95 GT Speedo 95GT 1979-1995 Mustang GT 5 12-06-2010 12:59 PM
speedo off k28gt 1996-2004 Mustang GT 19 11-27-2009 01:42 PM
Speedo is off... redbird2289 1996-2004 Mustang GT 14 09-10-2009 07:51 AM
speedo jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 06:21 PM
I need a speedo jimmy_beaner Mustang Parts for Sale and Wanted 4 05-13-2005 06:21 PM
11:56 PM
