Serpentine drive belt for 5.0HO w/o smog pump. - Mustang Evolution
Old 04-28-2011, 08:54 PM   #1
Blustreek's Avatar
Region: Hawaii
Okay these are the acc. I'm working off the crank:Alt,P/S pmp,Water pmp,idler plly,and the S/B tensioner.I've eliminated the emissions smog pmp.Question! Can anyone tell if a belt is made for this application? Cause that way I wouldn't have to buy the eliminator pulley and save the 70 bucks for gas or something.Also if I decide to go with a electric water pmp. is there a belt for this application too?
Because it would shorten the belt too since the water pmp. is elec.pwrd.
Blustreek '94 stanger gt cpe. Hardtop
V8 5.0HO 302cid stocker with Pacestter L/T headers 1-5/8's into a 2-1/2" collector through same dia.X-pipe and finishes off w/Flowmaster AT's 40series.
Project still inc. will update as mods get closer to glory day.Unjuiced!
Blustreek is offline   Reply With Quote
Old 04-28-2011, 09:35 PM   #2
the best way would propably be tojust run a string around the pulleys and then measure it.
Old 04-28-2011, 10:29 PM   #3
Blustreek's Avatar
Region: Hawaii
Re: Serpentine drive belt for 5.0HO w/o smog pump.
Yeah dreamstang that was an idea thought up but it was easier to ask since I was already on the internet.Anybody,answer if ya got da goods............Mahalo!!!!!!
Old 04-29-2011, 04:49 PM   #4
Titus Wadicus
svtlx's Avatar
bbunt posted a chart with different belt sizes for deleting smog, a/c and wut not.. i dont remeber where it is thogh. u could p.m. him and ask him bout it.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-30-2011, 08:01 PM   #5
Stang.racr's Avatar
There is a chart up cause I'm running the same belt as the one u are looking for but I don't remember number. It will be on the last two pages of forums that this chart is on
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-30-2011, 08:03 PM   #6
Stang.racr's Avatar
Last post 4,14 under new exhaust man
serpentine belt schematic??? 2002silverGT 1996-2004 Mustang GT 9 05-25-2007 12:00 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 11:10 AM
smog pump removal.. Belt size? GTOWNR 1979-1995 Mustang GT 9 05-04-2007 07:10 AM
serpentine belt greenpony02 Pre-2005 V6 Mustang 13 10-21-2004 08:04 PM
09:45 AM
