84 mustang lx question - Mustang Evolution
Old 04-29-2011, 03:18 PM   #1
Can I put different heads and intake manifold on? Like gt-40 or something
16218 is offline   Reply With Quote
Old 04-29-2011, 03:25 PM   #2
Titus Wadicus
svtlx's Avatar
Re: 84 mustang lx question
absolutley....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-29-2011, 05:23 PM   #3
Right now there's that big round intake would I be able to make the tubular kind or should I leave it like that? Would I have a problem with the fuel injectors?
Old 04-29-2011, 05:30 PM   #4
Titus Wadicus
svtlx's Avatar
your car is carberated right?
Old 04-29-2011, 05:30 PM   #5
No fuel injected
Old 04-29-2011, 05:31 PM   #6
That's why I want to do some mods I want to be stronger and faster
Old 04-29-2011, 05:35 PM   #7
Titus Wadicus
svtlx's Avatar
ok... i was confused cause u posted your car being an 84 and they didnt start efi till 86. if it's fuel injected, u can pretty much put any intake or heads on u want, the aftermarket has your world wide open
Old 04-29-2011, 05:41 PM   #8
So gt-40 heads and cobra upper n lower intake would fit with no problems or wiring problems?
Old 04-29-2011, 05:43 PM   #9
I think they started making them 79 but they were eh
Old 04-29-2011, 05:45 PM   #10
Titus Wadicus
svtlx's Avatar
no problems at all bud... u shouldnt be disapointed...
Old 04-29-2011, 05:46 PM   #11
Titus Wadicus
svtlx's Avatar
again, as long as it's fuel injected. like i said, 86 was the first year for efi. and u said your car's an 84. is it a conversion?
Old 04-29-2011, 05:53 PM   #12
Nope it's all stock at first I to thought it was carb but i didnt see an actual carb then I went to autozone and asked me if it was fi or carb then they gave me a magazine and yea it's fi
Old 04-29-2011, 05:56 PM   #13
Titus Wadicus
svtlx's Avatar
are u sure your car is an 84? and not to sound like an *** here. but if u have to ask the guy at autozone if your efi or carb, do u really wanna get into doin an intake and head swap?
Old 04-29-2011, 06:00 PM   #14
it's my first fox I seen the circular intake and just assumed it was carb then I was doing some maintenance and went to autozone And asked me then I red the magazine and look into it and it was fi not efi
Old 04-29-2011, 06:11 PM   #15
Titus Wadicus
svtlx's Avatar
ooooo. u got throttle body injection. tbi.... you could do the heads.. but ur pretty much stuck with the intake. i think they make sum aftermarket tbi intakes, but im not sure who and where to find them.
Old 04-29-2011, 06:31 PM   #16
Damn I havnt found any would the heads make much of a difference?
Old 04-29-2011, 06:38 PM   #17
heads will wake up any motor .but they would definately be restricted by factory intake.im sure summit or jegs could help you find the right combo for you
Old 04-29-2011, 06:38 PM   #18
Titus Wadicus
svtlx's Avatar
yea and no. depends if they sell an upgrade injector for your car and/or adjustable fuel pressure regualtor to fit your car. what gear do u currently have? a gear may help u if your afterthat kinda punch.
Old 04-29-2011, 08:19 PM   #19
Ewwww. TBI.
I'd lose that thing for an Edelbrock 600 and start there. GT40 heads would also be nice with an aftermarket Edelbrock intake manifold.
93CobraGuy is offline   Reply With Quote
Old 04-30-2011, 12:16 AM   #20
And the tranny it's auto I want to make it stick fox body parts are a dime a dozen so idc much about the trouble
Old 04-30-2011, 01:15 AM   #21
If you are going to go with a lot of power eventually, pick yourself up a TKO tranny for it. World of difference from the T5.
Old 04-30-2011, 02:30 AM   #22
I'm not going to put a lot of power so to say but it'll be a substantial amount
Old 04-30-2011, 08:06 PM   #23
Do u need a new cross membrane? Or anything? Will I need anything other then a rear end and tranny clutch cable, shifter and fly wheel?
Non Mustang Question Camo1967Mustang General Car Discussion 9 04-16-2011 02:26 PM
another mustang question junoS197Bl08 General Mustang Discussion 1 12-17-2010 07:15 AM
new to mustang have 3.8 question jeep6981 Pre-2005 V6 Mustang 10 03-10-2010 07:06 PM
Mustang Question... 94 Eclipse Gs Pre-2005 V6 Mustang 9 12-01-2005 06:43 AM
05 mustang question MonteCitan The Bar 15 01-27-2005 10:16 PM
10:13 AM
