over flow tank - Mustang Evolution
Old 04-29-2011, 07:05 PM   #1
over flow tank
so I installed an aluminum radiator and electric fan.since the factory overflow tank wraps around the factory shroud it is now useless.i bought an aftermarket aluminum cylinder shaped tank and I can't quite find a spot that I like.so i was wondering how important an overflow tank even is.i wouldnt think it would affect anything not having one, would it.
Old 04-29-2011, 07:16 PM   #2
06mustangmike's Avatar
Re: over flow tank
if you overheated it would go all over the ground!
06mustangmike is offline   Reply With Quote
Old 04-29-2011, 07:20 PM   #3
yeah but it is possible its gonna go on the ground anyway .
Old 04-29-2011, 07:26 PM   #4
the next question would be from normal operating temp to cool down does the fluid flow back and forth between the radiator and the overflow.
Old 04-29-2011, 07:47 PM   #5
Titus Wadicus
svtlx's Avatar
Re: over flow tank
dude, u need the overflow tank. where u put it is up to you. think of the overflow tank as an insurance policy for your motor.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-29-2011, 07:53 PM   #6
yeah i got you.i figured i did.i was just wondering.i dont know to much about the cooling system.
Old 04-29-2011, 08:04 PM   #7
gixxer007's Avatar
Re: over flow tank
Yea it is a must have I put mine on the left side of the radiator and think it looks ok their if that helps at all.
gixxer007 is offline   Reply With Quote
Old 04-29-2011, 08:14 PM   #8
ill figure out something.i just want to make sure it looks like it belongs there.
Old 04-30-2011, 06:14 AM   #9
gixxer007's Avatar
Re: over flow tank
Not the best picture of my over flow tank but its the only one I have for now to show you if it helps you at all.
Old 04-30-2011, 05:06 PM   #10
thanx, that looks really nice there.
Old 05-01-2011, 07:07 PM   #11
so I found a better tank to suit the room I have available and it should work out good.
Using a sumped tank Gettinmoremoney 1979-1995 Mustang GT 1 04-24-2011 09:11 AM
dropping tank on 99 GT 1ijack 1996-2004 Mustang GT 1 09-11-2010 08:23 AM
Sugar in the tank Black Panther Pre-2005 V6 Mustang 17 12-18-2004 06:25 PM
Tank i need a upload Thomas91169 The Bar 8 05-16-2004 02:52 AM
04:26 PM
