Rear Gears! - Mustang Evolution
Old 04-30-2011, 09:16 AM   #1
WhiteCobra94's Avatar
Rear Gears!
Since I drive alot of highway driving and when my mustang is done , would it be ok to switch my gears to 3.73s? cause with these 4.10s my RPM is at 4000-4500 RPMs, and that's only at 60-70mph
Thanks!
Old 04-30-2011, 09:24 AM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Rear Gears!
What transmission are you running? Because no OD transmission should be at 4-4.5 at 70 w/ 4.10's.
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-30-2011, 09:35 AM   #3
It's a aode rebuilt to hold up 550hp
Old 04-30-2011, 10:15 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Rear Gears!
-Will
i bet with that trans he's running a non-lock up converter which is why the rpms are so high.
im at 22-2300rpm at that speed with 3.45's. with a racing aod, and it because my converter doesnt have a lock up.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-30-2011, 10:30 AM   #5
Could that be why sometimes it knocks me out of OD to 3rd gear ?..... I have a new 2800 torque converter from boss hog that has a lock up. Should I wait and see with the new TC how it rides?
Old 04-30-2011, 10:46 AM   #6
Titus Wadicus
svtlx's Avatar
Re: Rear Gears!
nooo. that sounds like your trans. not having lock-up doesnt knock u into a lower gear.
Old 04-30-2011, 01:03 PM   #7
So if my torque converter is a non-lock up that would cause my RPMs to be 4000-4500 on the highway?
Old 04-30-2011, 05:50 PM   #8
Titus Wadicus
svtlx's Avatar
Re: Rear Gears!
honestly im not sure if it would be that high or not. but it's usualy 250-300 rpm higher than a lock up. think of a lock up as being like a fifth gear. being that high though, it sounds like your trans is in 3rd. i think u hvae valve body or solinoid issues with your trans. even in a non lock up it stays in the correct gear, doesnt cause u to drop to 3rd.
Old 04-30-2011, 06:50 PM   #9
Stang.racr's Avatar
X2 now I was running a 5 speed with my last 4.10s but I was like 2600 at 75 if I remember right. U not getting into od
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-30-2011, 07:56 PM   #10
Re: Rear Gears!
It sounds like you're riding in 3rd
-Will
Old 05-01-2011, 08:53 AM   #11
Well once my new motor is in and the new torque converter I'll see how it drives , but my question was ( how are 3.73s in a aode, compared to 4.10s )
Old 05-01-2011, 06:51 PM   #12
In my opinion, you should fix the problem of your transmission not going into overdrive first, see how it's working for you then, and then pose the question of whether or not you should switch to 3.73's. You might really like the 4.10s after you're in your final gear.
85GTPony is offline   Reply With Quote
Old 05-01-2011, 06:55 PM   #13
The car goes into overdrive because when I'm driving local I turn the overdrive off and when i push the red button on my shifter it kicks into overdrive,.... But sometimes (not everytime) on the highway I'm in overdrive and it'll shift down to 3rd then right back into OD, I I'm definitely getting that checked out tho !
Old 05-01-2011, 07:17 PM   #14
Well I'm just saying 4000-4500 on the freeway definitely Indicates you are not in overdrive. If you are in fact going into overdrive something is seriously wrong with your setup, like maybe your converter is just slipping like crazy constantly. In either case, yes you will need to fix whatever the problem is first!
Old 05-01-2011, 07:23 PM   #15
Re: Rear Gears!
It's almost impossible to answer "how are 3.73's compared to 4.10's". It really depends on your specific combo. With the right engine/cam/converter combo you wouldn't need as much gear....if you went with a different setup (something like a larger cam and less converter) then the 4.10's would almost be required.
It really depends on your combo. I would ask your engine builder what converter and gears they recommend
-Will
Waffles
Old 05-01-2011, 08:07 PM   #16
-Will
Ok will do! My head/cam/intake is Edelbrock Performer Heads and Intake , with trickFlow stage 1 cam
Old 05-01-2011, 08:47 PM   #17
Titus Wadicus
svtlx's Avatar
Re: Rear Gears!
wooot? your running a stage one with 4.10 gears. you would prolly definatley be happier with 3.55-3.73
Old 05-01-2011, 09:00 PM   #18
Yea, well when I bought the car 6 years ago it was bone stock and all I did to it was pulleys, full exhaust , 4.10s and lowered it, and last year I put a new trans in it, that car's been like that for 3-4 years now, and now she's getting a full make over !!!! I don't Mind fixing the problem and getting a set of 3.73s
Old 05-01-2011, 09:02 PM   #19
Titus Wadicus
svtlx's Avatar
Re: Rear Gears!
im just fukn wit u. u may like the 4.10's
Old 05-01-2011, 11:41 PM   #20
Re: Rear Gears!
What converter?
-Will
Waffles
Old 05-02-2011, 12:44 PM   #21
What converter?
-Will
I just bought the Boss Hog 2800 Stall
rear gears by necessity jedwards242000 Pre-2005 V6 Mustang 23 06-04-2008 11:14 PM
Rear Gears sledgehammer Pre-2005 V6 Mustang 16 12-06-2007 08:19 AM
rear gears tim11 Pre-2005 V6 Mustang 45 11-12-2005 02:40 AM
Rear Gears TBone Pre-2005 V6 Mustang 16 05-04-2004 11:10 PM
Rear End gears? RedDragonV6 Pre-2005 V6 Mustang 3 03-18-2004 04:12 PM
11:34 PM
