engines that fit into 94 gt conv - Mustang Evolution
Old 04-30-2011, 10:09 PM   #1
workmail21's Avatar
I need to kno what other engines fit into my stang because my engines messed up and I'm having trouble finding another 94 around me, I just want something kinda easy not a lot of fabrication?
workmail21 is offline   Reply With Quote
Old 05-01-2011, 01:01 AM   #2
workmail21's Avatar
I found a 2011 totaled out would this b the same motor that is the "coyote" crate motor?
Old 05-01-2011, 01:54 AM   #3
Re: engines that fit into 94 gt conv
Assuming you have a 5.0 in your '94 then no, definitely not the same thing. Two completely different animals.
I'm really surprised you can't find another 5.0 around you for cheap. I can usually come across them for $500 or less all day long where I am.
93CobraGuy is offline   Reply With Quote
Old 05-01-2011, 08:56 AM   #4
workmail21's Avatar
Yea that's what everyone's been saying but I can't find one with in 300 miles of me and they are 700-1200 which I would pay but I don't wanna drive 6 hours each way.
What about the trans and engine out of a lightning would that fit?
Old 05-01-2011, 11:27 AM   #5
Titus Wadicus
svtlx's Avatar
the only thing easy you can stick in there is another 5.0... that would be easy to install. lightening wont work, nothing 4.6 mod motor based will work. sounds like you need to keep looking. evrything else would cause u to have the change the wiring harness and k-member. did u try to find a 5.0 out of a truck or van? they would work also (but must be a 5.0) all you would have to do is change the intake and maybe the oil pan, if you cant find a 5.0 outa a stang. you could also use a lincoln mark 7 or a crown vic.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-01-2011, 11:28 AM   #6
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Find an explorer 5.0 longblock. Better heads/intake.
-Will
Knight F Mohawk is offline   Reply With Quote
Old 05-01-2011, 11:52 AM   #7
Titus Wadicus
svtlx's Avatar
-Will
haha that's wut im running less the heads and intake...lol.
Old 05-01-2011, 01:23 PM   #8
Stang.racr's Avatar
Me to in one of mine
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-01-2011, 01:55 PM   #9
workmail21's Avatar
What years did the explorer have the 5.0?
Old 05-01-2011, 09:40 PM   #10
What year did the explorer have the GT-40 heads?
Dexter is offline   Reply With Quote
Old 05-01-2011, 11:29 PM   #11
workmail21's Avatar
So does the 5.0 explorer engine drop right in? If not what do I all need from the donor explorer?
Old 05-01-2011, 11:38 PM   #12
If you're going to pull apart, just take the whole thing
-Will
Waffles
Old 05-02-2011, 08:43 AM   #13
Titus Wadicus
svtlx's Avatar
if u cant look at it and know what needs swapped.... you prolly dont need to do the swap (have someone do it for u). it's pretty straight forward.
Old 05-02-2011, 04:31 PM   #14
workmail21's Avatar
Yea I am having someone else do it I just gotta get all the stuff that's y I wanted to kno what I all needed off the explorer to put the motor in the mustang
Old 05-02-2011, 04:40 PM   #15
gixxer007's Avatar
Wow I see a ton of 5.0 motors around here for saleand even some built short blocks for the price you are getting on a stock block.
I would say keep look and check craigs list I seem to have a lot of good luck with that once you sort out the scams of course.
gixxer007 is offline   Reply With Quote
Old 05-02-2011, 06:25 PM   #16
Play nice you meanie head
-Will
Waffles
Old 05-02-2011, 06:35 PM   #17
Titus Wadicus
svtlx's Avatar
-Will
i wasnt tryn to be mean, i was just being honest. all he needs are fresh gaskets, and transfer the stuff from the stang block to the explorer block, he doesnt have to buy anything really. hence, if u cant look at it and know what it needs... u prolly shouldnt be doint it.
i realize ive been a prick today, but this wasnt one of those times...
Old 05-02-2011, 06:54 PM   #18
workmail21's Avatar
Hey it wasn't mean I kno what he's saying I just wanna make sure the guy doing it for me has everything thanks for all the help, I didn't wanna buy something I couldn't use or didn't have everything I needed
Old 05-02-2011, 06:55 PM   #19
workmail21's Avatar
Yea I'm having trouble around here I found one but it had a buttload of miles I don't wanna spend a bunch of money and then have to spend it again
Old 05-02-2011, 07:01 PM   #20
Titus Wadicus
svtlx's Avatar
he's gonna need to swap intake (im pretty sure).. remove the cam sensor and install the dizzy... swap oil pans, and swap timing cover. if your motor is stock, just run the cam and heads on the explorer, your better of.
the main thing u will need is a engine rebuild gasket kit. i know im forgeting something.. but u dont really need any hard parts... it's just swapping one era to the next is all....
on the up side... the explorer (most) block is the mexican block made from a magnesium alloy and is lighter than the older 100% cast iron blocks. someone else told me, and i didnt believe them till i drug both blocks across the floor.
Old 05-02-2011, 07:04 PM   #21
Titus Wadicus
svtlx's Avatar
o yea, get sum cheap "100bucks shipped" headers from ebay to run those heads... if not, u will need to take your stang heads and put them on the explorer block. the xplorer block is equiped with gt40p heads. do yourself the favor, keep the heads and just get sum headers
Old 05-02-2011, 07:51 PM   #22
workmail21's Avatar
Ok sound good ill have to get all that thanks for the help
Old 05-02-2011, 08:32 PM   #23
workmail21's Avatar
Would a 2000 explorer 5.0 work or is that to different
Old 05-02-2011, 08:38 PM   #24
Titus Wadicus
svtlx's Avatar
i think 97 or 98 was the last year for the 5.0 in the xploder... as long as itsa pushrod 5.0 it will work, regardless of year. i had a crown vic in minwe a long time ago....lol.
Old 05-02-2011, 09:55 PM   #25
workmail21's Avatar
Well I think its out a mountaineer but its pushrod 5.0 ok cool uve been a huge help and u saved me about 1000 bucks thanks a lot
Old 05-03-2011, 07:14 AM   #26
Titus Wadicus
svtlx's Avatar
im glad i was able to assist u with helpful info.
Engines... Firewolf Pre-2005 V6 Mustang 12 10-10-2009 12:07 AM
with 5 lug conv. , will 18 x 10"s fit, another newbie from louisiana L.j. New Member Introductions & Greetings 10 05-06-2009 06:55 PM
MYT engines Ken The Bar 5 06-22-2006 05:41 PM
2 v6 engines 2000 Dunkman Mustang Parts for Sale and Wanted 4 09-23-2004 12:08 AM
roush engines tek55 The Bar 13 12-19-2003 11:22 PM
03:05 PM
