Mallory unilite help 302 - Mustang Evolution
Old 05-02-2011, 07:36 AM   #1
I have installed a Mallory unilite dist in my 87 carbed 5.0 and it keeps backfiring out of Carb no matter wat timing
83mustang is offline   Reply With Quote
Old 05-02-2011, 07:42 AM   #2
Re: Mallory unilite help 302
Are you confident the timing is not 180 degrees off? If not, turn the dist 180 and try again.
Old 05-02-2011, 07:45 AM   #3
Titus Wadicus
svtlx's Avatar
i agree, you may only be off a tooth or two.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-02-2011, 07:52 AM   #4
I have turned and it gets better but wen u hit gas it backfires and dies and I've put at tdc and 10 degrees btc
Old 05-02-2011, 07:56 AM   #5
Are you sure you're at TDC on the intake stroke and not the exhaust stroke?
Old 05-02-2011, 07:56 AM   #6
Yes took off plug and rotated til finger blew off
Old 05-02-2011, 07:57 AM   #7
Titus Wadicus
svtlx's Avatar
im telling u dude, you need to take it out and put it back in... it's not in right, it's off a few teeth.
Old 05-02-2011, 08:06 AM   #8
Will try that but any other ideas and no ballast resistor either do I need one? And I have red to + coil and switched 12v and black to negative coil and brown to geou
Old 05-02-2011, 08:08 AM   #9
Titus Wadicus
svtlx's Avatar
does your tach work?
Old 05-02-2011, 08:10 AM   #10
Not hooked up
Old 05-02-2011, 08:51 AM   #11
I need any and all suggestions I've timed it to 10 degrees btc and at tdc and I've turned dist both ways and I will eventually run out of gas because it will back fire and stall wen I try to take off and doesn't have full power that it sshould I need an hei and I'm in Cincinnati Ohio any help?
Old 05-02-2011, 09:13 AM   #12
Titus Wadicus
svtlx's Avatar
im in cbus... but i dont have any dizzys that old. all i have is efi stuff. anyway, im tell'n you dude, that dizzy is in wrong. you cant turn it enough backward or forward to compensate for it being off a few teeth.
if you have to. take it out, advance it one tooth, then start it. keep doin it till it runs right. that's all i can tell u. ive had to do it before (several times).
try this. get engine to number one cylinder up on compression stroke. drop in dizzy and be sure the rotor button is pointing straight back towards center of firewall/motor. if the rotor isnt facing straight back "12 o'clock (straight up)facing motor" then you aren't on number one
Old 05-02-2011, 09:20 AM   #13
Ok I will try that and I put rotor torwards #1 plug on dist and its right firing order so with that at 12oclock where do u suggest I put rotor cap at
Old 05-02-2011, 09:30 AM   #14
Titus Wadicus
svtlx's Avatar
it's not a chevy..... putting rotor towrds number 1 plug is gonna have your timing all fukd up. there should be number one spot on cap... make sure it's "intialy" pointing to rear of motor.
Old 05-02-2011, 09:31 AM   #15
stampde's Avatar
when the 'ol finger blows out , check and see if the timing marks are close : as in tdc ,,, if not rotate it back by hand till they line up ,pointer on timing case and mark on balancer, then drop dist back in ... only use the finger to get it close ( and not to be a smart *** but ,your using #1 cyl as pass side front plug , wright ? )
2011 GT Auto
Old 05-02-2011, 09:40 AM   #16
Yea pass side and lined up with tdc my piston at top and I did face rotor button at 11 o'clock at number one plug
Old 05-02-2011, 09:59 AM   #17
stampde's Avatar
hmmmmmmm, could be the unilite ??? i had a lot of probs with them in the past , so many that i always use MSD any more
2011 GT Auto
Old 05-02-2011, 12:28 PM   #18
Had msd and they go bad it could be Mallory I guess have u ever had that problem due to bad module
Old 05-02-2011, 12:40 PM   #19
stampde's Avatar
if i remember i think i kept burning out the module on my unilite ( long time ago )
but a friend of mine had a similiar prob to yours ,backfiring and it was the unilite
2011 GT Auto
302 Blackpony Classic Mustangs 6 12-21-2010 09:05 PM
i have a 66 302 need help guitarsav276 Classic Mustangs 5 03-30-2010 07:52 AM
Got the 302 SC_STEEDA Classic Mustangs 1 03-09-2010 06:59 PM
68 302 V8.. Fishers Stang Classic Mustangs 13 04-27-2006 05:57 PM
302 Question drummerstang98 1979-1995 Mustang GT 7 09-17-2005 12:17 PM
03:53 AM
