94-95 a/c? - Mustang Evolution
Old 05-02-2011, 09:03 AM   #1
Titus Wadicus
svtlx's Avatar
94-95 a/c?
ok, as everyone knows im doing a 5 liter swap into a 97. i got it wired up for the most part but i need help with this.
pressure switch that goes into reciever dryer on passenger side. what color are the wires that go into the pressure switch?
where do they lead? i cant find them on the main harness that goes into firewall.
what color are the wires going into the a/c clutch? where do they lead too on the harness?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
10:36 AM
