injector question - Mustang Evolution
Old 05-02-2011, 04:55 PM   #1
91gt's Avatar
injector question
I'm new to this site and I have a 91gt I put a e303 cam gt40p heads tricks flow upper and lower intake 70mm throttle body cai and I put 24lb injectors in it and now when I put the correct maf in it doesn't run right at I could use some help I thinking I should put the stock injectors back in it
91gt is offline   Reply With Quote
Old 05-02-2011, 05:17 PM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: injector question
Welcome n00blet
If you install 24's on the stock MAF, it will not run well if at all...if you do injectors & MAF at the same time, you should be fine
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 05-02-2011, 05:31 PM   #3
91gt's Avatar
That's the thing it runs better on the stock maf
Old 05-02-2011, 05:45 PM   #4
Titus Wadicus
svtlx's Avatar
are you running an adjustable fuel pressure regulater? what do u have the fuel pressure set at?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-02-2011, 05:50 PM   #5
91gt's Avatar
No I don't have an adjustable regulator and I haven't checked my fuel pressure yet
Old 05-02-2011, 05:53 PM   #6
Titus Wadicus
svtlx's Avatar
well im sure that's your issue, and y the stock meter runs better than the calibrated one. stick the stock meter back on it till u get an adjustable regulater and a fuel pressure gauge. your gonna need to tune the fuel pressure to get it to run with the calibrated meter. but once u got the right fuel pressure dialed in...you'll be very happy.
Old 05-02-2011, 05:55 PM   #7
Titus Wadicus
svtlx's Avatar
dont scrimp on the fuel pressure gauge... u need to see where your at. 1-2lbs. increments makes a huge difference.
Old 05-02-2011, 05:59 PM   #8
91gt's Avatar
Thanks very much I hope it fixes the problem cause I got beat by my buddy's stock 87 5.0
Old 05-02-2011, 06:00 PM   #9
Did you try clocking the MAF?
-Will
Waffles
Old 05-02-2011, 06:03 PM   #10
91gt's Avatar
What's clocking
Old 05-02-2011, 06:05 PM   #11
Originally Posted by 91gt View Post
What's clocking
Turning it....the C&L I had on my 93 LX didn't work for crap if the sensor was at 12 o'clock. It worked great at roughly 3.
-Will
Waffles
Old 05-02-2011, 06:05 PM   #12
91gt's Avatar
Haven't tried that
Old 05-02-2011, 06:09 PM   #13
Titus Wadicus
svtlx's Avatar
-Will
i think someone had your shyte on wrong to start with im just joshn wit ya...
Old 05-02-2011, 06:13 PM   #14
I had never heard of it either.....but it worked.
-Will
Waffles
Old 05-02-2011, 06:14 PM   #15
Titus Wadicus
svtlx's Avatar
i guesse u learn something new everyday....
Old 05-02-2011, 06:30 PM   #16
-Will
Had the same issue with my 92. Had to spin it to a few different positions before it acted right. It's not a straight run pipe so turbulence will build up some and alter the air flow where the sensor may be.
Alscobra is offline   Reply With Quote
Old 05-03-2011, 07:58 AM   #17
Stang.racr's Avatar
Never heard of that
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-03-2011, 05:08 PM   #18
91gt's Avatar
Ok so I checked my fuel pressure and at idle it's at 34 and when I give it gas to drops to 20
Old 05-03-2011, 05:39 PM   #19
Titus Wadicus
svtlx's Avatar
wow... are you sure? that's awful low. is that a stock fuel pump? that's with the 24lbs injectors right? if so, i think you may need to upgrade your fuel pump, at least one step up to a 110lph. the stock pump max's at 88lph.
anything below 25-28lbs and i think your gonna start running into spray pattern issues.
Old 05-03-2011, 05:39 PM   #20
When was last time you changed your fuel filter?
-Will
Waffles
Old 05-03-2011, 05:42 PM   #21
Titus Wadicus
svtlx's Avatar
fyi.... stock fuel pressure setting is 38-40psi, and your at 34 at idle with no load on the motor. if your filter is ok you need to upgrade fuel pumps bud
Old 05-03-2011, 07:13 PM   #22
91gt's Avatar
I took the old Fuel pump out and I found the hose split
Old 05-03-2011, 07:25 PM   #23
LK1
Fuel pressure is 39psi with no vacuum applied to gauge, a QUALITY calibrated maf for 24lbs inj will run much better than a stock or c&l meter - no clocking will be needed!
LK1 is offline   Reply With Quote
Old 05-04-2011, 09:09 AM   #24
91gt's Avatar
So I put just a stock fuel pump my buddy had and it runs strong now
Old 05-04-2011, 02:30 PM   #25
Stang.racr's Avatar
That's good man. Glad it's back rolling
Old 05-04-2011, 04:16 PM   #26
Titus Wadicus
svtlx's Avatar
awsome!!!! i knew it was pump related.
Old 05-04-2011, 04:29 PM   #27
91gt's Avatar
Yeah thanks for the help
4.3 Stroker Injector Help Silverstealth98 Pre-2005 V6 Mustang 1 01-03-2011 07:24 PM
Need help with injector type Myles 1996-2004 Mustang GT 1 12-20-2010 06:25 AM
injector size.... help!!! svtlx 1979-1995 Mustang GT 5 04-18-2009 06:07 PM
Injector questions... DarkShadow Pre-2005 V6 Mustang 19 05-23-2006 05:11 PM
Fuel injector how to's? DarkShadow Pre-2005 V6 Mustang 4 03-08-2006 08:41 PM
06:54 PM
