Ac high and low pressure ports? - Mustang Evolution
Old 05-03-2011, 07:52 PM   #1
SleepingStang's Avatar
Can someone tell me on my 92 LX which AC port is high and which is low. I assume that the port on the compressor is high and the port on the tube roughly in the center of the engine bay is low. Thanks.
SleepingStang is offline   Reply With Quote
Old 05-03-2011, 09:37 PM   #2
Send a message via Skype™ to Texastboneking
Re: Ac high and low pressure ports?
r134a system? if so you can tell by the size of the ports. one is big and one is small
Texastboneking is offline   Reply With Quote
Old 05-04-2011, 05:54 AM   #3
Titus Wadicus
svtlx's Avatar
sooo im gonna assume that you are in the process of doing an r134a conversion? not sure how you are goin bout it... but you should do this if you have'nt already.
autozone or any parts retailer... you can buy the r134a conversion fittings, about 5-7 bucks. screw the fittings onto the factory r12 fittings. you may or may not need a valve stem remover in order to install one of the ports. your r134a fill hose will only go on one port. the high and low ports are differnt sizes so u cant mess it up.
i cant remeber which is which on the car, so i help this lil bit of info helps...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-04-2011, 11:15 AM   #4
Yes I am converting but am slowly piecing the system together. Anyone with the conversion or without the conversion have theirs marked or color coded red / blue? Just need to know which one is which so I can order the correct fittings. Thanks.
Old 05-04-2011, 11:55 AM   #5
93slowstang's Avatar
If you buy a kit it should only come with the low side fittings. The low side line itself is the larger one and the fitting is the one on the pump itself.
Old 05-04-2011, 03:22 PM   #6
Thanks.
Old 05-04-2011, 04:26 PM   #7
Titus Wadicus
svtlx's Avatar
ive never seen a kit with just one side. all the conversion kits ive ever purchased had both sides. not too mention, if you are using professional gauges (not autozone stuff) or using an actual recycle/fill machine... you gotta have both conversion fittings installed.
Old 05-04-2011, 09:30 PM   #8
Yeah just realized that, never really been too worried about the high side connection because the 134a gauges we use have a retrofit adapter that we use for the high side. Been awhile since I've done a conversion.
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 04:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 05:17 PM
A/C low pressure port magnettarpit 1996-2004 Mustang GT 0 05-20-2007 08:32 AM
run 16.3 in high heat/humid...low temp good for 15's? tedness Pre-2005 V6 Mustang 7 01-02-2006 12:56 PM
what to use to get crap off of lower intake ports? tire Pre-2005 V6 Mustang 3 03-01-2004 09:11 AM
10:23 PM
