new to this site - Mustang Evolution
Old 05-04-2011, 12:30 AM   #1
new to this site
Hey fellas i had a question needed some opinions, what's a good cam to use with gt40 heads????
stanger72truman is offline   Reply With Quote
Old 05-04-2011, 08:12 AM   #2
Welcome! I don't know myself but maybe someone who does will chime in.
Old 05-04-2011, 08:14 AM   #3
A.K.A. Baby-D!
Re: new to this site
welcome! plenty of knowledgable users that should chime in soon!
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 05-04-2011, 08:21 AM   #4
Joshy's Avatar
Welcome
www.petom.biz
Joshy is offline   Reply With Quote
Old 05-04-2011, 10:22 AM   #5
wereKEV's Avatar
welcome.
wereKEV is offline   Reply With Quote
Old 05-04-2011, 10:24 AM   #6
welcome!
Old 05-04-2011, 10:31 AM   #7
I called Steeda and they said the Steeda #19 cam would be good
Old 05-04-2011, 12:28 PM   #8
Stang.racr's Avatar
There are plenty of good cams out there if u wanna stick with ford parts I would say a b or e cam. I like trick flow stage 1 and that's what I'm getting next just make sure u car is geared for the cam u choose
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-04-2011, 12:31 PM   #9
Geared as in rear end??
Old 05-04-2011, 12:48 PM   #10
Stang.racr's Avatar
Yeah as in rear end some cams u will need atleast 3.73s because they will have a power range of 3500-7000 just an example anyway also SOME cams will be listed as 5 speed only
Old 05-04-2011, 12:50 PM   #11
Yea i put a 4.10 in it, its an AOD, u recommend a diff cam?
Old 05-04-2011, 12:52 PM   #12
Stang.racr's Avatar
U plan on building a mild 275ISH hp motor or u gonna spray it or what
Old 05-04-2011, 12:55 PM   #13
I dnt know really, my setup is 4.10 gear, shift kit, shorty headers with hpipe & flows, BBK CAI with 80mm maf, 75mm TB, Cobra upper & lower, 24lb injectors, got gt40 heads just gotta get cam & install both, haven't tuned yet obviously waiting to put heads & cam in
Old 05-04-2011, 01:07 PM   #14
Stang.racr's Avatar
Another option is instead of putting in a larger lift cam would be to keep your stock cam and ditch the 1.6 roller rockers and get 1.7s and u get almost same effects with 10% of the labor. Just an option though. Alot of folks do it cause stock cams are good on the bottle. The aluminum roller rockers are lighter and stronger than stock ones, rev faster and well open valves more giving a more lopey sound. I'm running the same setup as u on dd and I'm getting a trick flow cam just not gonna tear apart motor just for cam swap
Old 05-04-2011, 01:22 PM   #15
Wow so i just use stock cam and change rockers to 1.7 and that's it?? Will it give that cam sound or sound normal, what about if my heads have 1.7 rockers & still get a cam would it make anymore of a diff in hp?
Old 05-04-2011, 02:05 PM   #16
Stang.racr's Avatar
Well more lift gets closer and closer to piston and valve clearance stock cams usually have more duration but less lift. U are increasing lift so get aftermarket cam effects. It will change the sound alittle. The bigger cam lopes when it opens big then shuts right away. With bigger rr it will open valves more and they are easier to instal. YouTube poops up foxbody roller rocker swaps and it's a video that helps. It's safer than putting some extreme big cam in your car and losing drive ability, an easier idle, not to meNtion what happens to brakes when vacuum is changed but huge cams
Old 05-04-2011, 03:26 PM   #17
bbunt302's Avatar
I'd recommend something like a XE266HR or XE270HR from Comp Cams or a Crane 2020 (now 4442111).
Scary stuff.
Old 05-04-2011, 03:34 PM   #18
Cool thx guys, another question for ya, when i get a tune will the 80mm maf & 24lb injectors work fine or do i have to get fuel regulator kit?? Havnt had tune yet & maf hasn't been calibrated & no problems with computer, but who knows if actually working together like should
Old 05-04-2011, 03:51 PM   #19
Stang.racr's Avatar
Just make sure u get the maf that's set for 24#s also I'm still running 19s on both my cars I would like to tune later on just played it old school ways so far
Old 05-04-2011, 03:54 PM   #20
The maf hasn't been calibrated for 24's yet, didn't know if tune would calibrate
new to the site fastazzcobra New Member Introductions & Greetings 13 03-06-2011 11:13 AM
New to the site! Green96 New Member Introductions & Greetings 12 09-14-2010 06:17 PM
New to the Site StangPride New Member Introductions & Greetings 8 02-09-2009 07:33 PM
New to the site cfighterace Pre-2005 V6 Mustang 17 08-05-2008 11:00 AM
hi.. new to the site Taywi New Member Introductions & Greetings 15 10-12-2006 03:33 PM
03:59 AM
