Rear gear ratio? - Mustang Evolution
Old 05-10-2011, 05:20 PM   #1
86gt's Avatar
Rear gear ratio?
Does anyone know what the stock rear gear ratio was in a '91 gt?
86gt is offline   Reply With Quote
Old 05-10-2011, 06:30 PM   #2
91gt's Avatar
I think it's 3.08
91gt is offline   Reply With Quote
Old 05-10-2011, 06:38 PM   #3
gixxer007's Avatar
Re: Rear gear ratio?
I am also almost sure they are 3.08 also.
gixxer007 is offline   Reply With Quote
Old 05-10-2011, 06:42 PM   #4
99.9% it's 3.27
11SHELBYGT500 is offline   Reply With Quote
Old 05-10-2011, 09:13 PM   #5
Some....91 GT 5-speeds had 3.08 gears
............91 GT AODs had 3.27 gears
From what I have researched, they came from the factory with 2.73 gears, but owners could check the gear ratio change box and get the ratios listed above installed for free.
Just look at the tag on the rearend. It will tell you what you have, or had if someone changed them.
Or, you can remove the cover and count the teeth on the ring and pinion gears, then divide the ring gear tooth count by the pinion tooth count.
Old 05-10-2011, 10:00 PM   #6
86gt's Avatar
Thank you guys for the input, I appreciate it!
Gear ratio? Joshfelder 2005-2010 Mustang GT 9 03-14-2011 08:03 AM
Tranny gone did use the 2.3 trans on my v8 n likd the gear ratio but now wat to do? Justbust1n 1979-1995 Mustang GT 18 02-26-2011 08:07 PM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 11:31 AM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
12:59 AM
