question of the decade, will pay for correct answer - Mustang Evolution
Old 08-15-2007, 08:07 PM   #1
why won't timing light work with spout out. light connected to battery, and number one spark plug. put spout in, timing light will work. what's the deal?
chrismillion is offline   Reply With Quote
Old 08-16-2007, 07:58 AM   #2
Re: question of the decade, will pay for correct answer
Have you tried using another timing light?
That's the only thing I can think of if the light works with the spout in.
The only thing taking the spout out does is cuts the computer control to the timing off. So, unplugging the spout shouldn't make a difference.
Old 08-16-2007, 02:29 PM   #3
i got codes pulled and it was 211, 212. just put a stator in and after clearing the codes i got 212 again which is ignition module circuit failure/SPOUT circuit grounded. i had the TFI checked at O'reily autoparts store three times last week plus twice yesterday and the module keep passing the test. now as far as the SPOUT goes, when i tap into the pink wire with a test light, the engine dies in an instance. when i use the test light to on the pink wire while trying to crank the engine, the engine will not crank. what exactly is a grounded SPOUT? the car is bucking and backfiring and i can't figure out why!!! help!!!
Got An Answer To My Question geminigirl New Member Introductions & Greetings 2 03-07-2008 10:12 AM
bush finally comes correct... dark The Bar 9 08-27-2004 12:39 PM
Ask a question and I can answer it., I am OZ Ken The Bar 88 03-23-2004 01:31 PM
chip correct Falcon Pre-2005 V6 Mustang 19 01-04-2004 03:34 AM
Pay Pal question: Rellik The Bar 26 11-06-2003 08:34 PM
12:08 AM
